Old 03-19-2010, 12:16 PM
Squido Squido is offline
Default Re: In deck Livewell issue
I am doing the same project right now in my 23'. I am going with a 500 gph in and a 500gph going out. I will regulate with the valves on the out side of the tank. I am going to put my pump out thru hull high off the waterline next to my bilge pump out. So I can see it running even when I am up on plane. If it stops running for some reason I can see it and I know to go look right away. If something is below the water line you might not catch it right away. I will post pics later. I will be installing pumps tonight.
Old 03-19-2010, 12:32 PM
Basspond Basspond is offline
When my 20 was restored the in deck livewell was redesigned so the corners were not so square, making it more of a circular shape. It has a pump going in at the bottom and another pump out at the top. If I don't run the top pump the water just comes out on the deck channels and goes out the scuppers.
It isn't a perfect system, but it does keep quite a few bunker (pogies, menhaden, etc.) alive for a long time.
2001 23 Regulator 2006 F250 Yamaha
Old 03-19-2010, 12:38 PM
trave2 trave2 is offline
Some good ideas thanks! Squido thats what I had in mind too. I have a jabsco pump already plummed to the well w/ a clam shell on the hull. The problem is that it will not empty or circulate water. The bottom hole in the well is a straight shot to a seacock in the transom under water line, I'm thinking of removing that line or putting in a Y fitting and putting a pump out to the hull above water line like you are doing. The jabsco evacuation pump (fish box pump)is what I had in mine for pump-out. You might want a bigger gpm pump for the outflow just in case. Thanks for the tips and let me know how yours turns out.
Old 03-19-2010, 05:54 PM
Do you guys have a pic of your outflow scupper,thru-hull?
Old 03-19-2010, 07:33 PM
The large bronze one, but my well is above deck and I feel this is really the way to go. As mentioned flow is key as is round or oval shape is Far better imo. Gogs will swim in the corner, stay there and die. You don`t want any plumbing in the way inside the well as they get beaten every time they hit obstructions.
If the flow is right the bait can just sit there and get h2o/o2. Put your intake jet at the of end of the "Nascar" turn to the front straight. I think this is the first time I`ve ever typed Nascar.
Cheers,
GFS
Old 03-19-2010, 09:49 PM
4 inch Rabud strainer, mid level in transom live well.
(Just to the right of port Bennett ram)
I have a 4 inch Rabud on the inside of the live well to
close it off.
See ya, Ken
Old 03-22-2010, 02:49 PM
BoniB BoniB is offline
Default In deck Livewell issue
Just picked up my 74' 20SF and have been thinking about how to plumb the live well out. I have an existing thru hull with sea cock down in the bilge now that was used for a SW wash down. Since the thru hull is below the waterline and the fish box how well would it fill if I ran a line directly from the seacock to the live well? Then I would just use one pump to remove water. The livewell is on the small side and kinda squared off for using bunker but I would like it to be usable.
I'll probably end up using my portable 30 gallon round livewell; fed from the SW wash down pump and let it overflow into the motor well.
BoniB
26 Regulator Express
74' 20SF
