Old 08-24-2010, 12:12 AM
Default Re: 23 CC minty green!
Wildman - I think I can hook you up with that hatch. I have one in my scrap pile that I was saving for a 122 gallon tank . . . that might never happen.
Old 08-25-2010, 07:43 PM
Wildman Wildman is offline
Bigshrimpin I gave you a call yesterday.
This is the box I need a cover for.
Here is the console and windshield that will be up for sale, Best offer. I had thought I could use it, but I am going with my original one that fits my T top.
Old 08-25-2010, 08:09 PM
More stuff I wont be needing that I will be putting up for sale.
The stainless trim piecs for around the transom, they have nice turning in them most are very flat.
Old 08-27-2010, 12:08 PM
I have it. I'll call you this weekend.
Old 08-27-2010, 02:17 PM
loon loon is offline
How much are you thinking of for that console? (Not for my Seacraft)
Old 08-27-2010, 02:56 PM
Loon Ill PM you my cell # give me a call and make an offer!
Old 09-04-2010, 03:33 PM
Been ordering parts and figuring out my deck's lay-out the last couple weeks.
I had a few minutes in the evenings last week so I thought I would give the hull a good buffing. The old gellcoat shined up nicely!
Most of the white junk is coming off easy. The tape lines from old Shrink wrap jobs are proving difficult, but its not too bad. One side is totally done and I started the other side.
Old 09-05-2010, 08:51 PM
Can I remove this bulkhead and replace it with a one piece unit without pulling the cap off the boat?
Old 09-05-2010, 09:00 PM
Got most of the junk and water out of the hull, and tore up the (rotted) 1/4in thick gas tank shelf. This will be replaced with strips of Penskie board laminated with glass.
I also tore out the front bulkhead as it was not glassed over and the bottom had started to rot. This will also be replaced with Penskie. I left 2in 'cleats' on the sides to glue the new board to.
The keel stringer is wet and the top 1/2in is rotted. They NAILED a filler strip between the gas tank shelf and the keel, water got in and does what water does! I will be replacing it with a piece of PVC pipe cut in half and laminated over.
The shelves on eiher side of the keel in the furthest aft part of the boat (the orignal bait well used to sit here) will be rebuilt and I am planning on mounting my wash down and live well pumps on them. I also removed the old thruhulls and strainers from here today.
Old 09-05-2010, 09:54 PM
NO, You will need to:
1.) Construct a new bulkhead using the old one as a pattern
2.) Cut out new hatch and any other holes
3.) Cut new bulkhead top to bottom @ centerline
4.) Install new in two pieces one side at a time
5.) Quick fair the two seams
6.) Sand, Paint & Caulk
I used 3/4" PVC Board
