Old 10-21-2010, 07:16 PM
JohnB JohnB is offline
Default Re: 23 Rebuild
The sole is mounted at the factury height.
Unless you get 2 guys standing in the corner at rest, the scuppers stay dry. I also have the rabud covers on them, so water doesn't come in. Cockpit drains fine.
I mounted my bracket as low as I could get it to get max floatation at rest.
JohnB / 23' SeaCraft
Old 10-21-2010, 10:06 PM
Nice project How much was added to the stringer height? Like others have said...I never have a wet floor. My 23 was converted from twin I/O to an outboard bracket. Its the "large console" model. Bats were moved to console. New tank is 80gals. I dont have "as built" measurements but below is my sketch plan. I love the boat and the way it came out. Good luck with yours!
and my boat
1974 23SF
Old 10-22-2010, 08:55 AM
Sweet ride!
Old 10-22-2010, 11:27 AM
shine shine is offline
Moderator
Hermit, thats very helpful. I am after a very similar setup. Is your sketch pretty accurate in terms of tank location?
The stringers have been raised 2" above normal. I dont have the liner, so I do not know the original level of the sole. The original liner would have had a core, plus the putty that was used between the liner and the tops of the stringers. I could just be back to normal with my 2" raised stringer plus new sole. My new sole will be bonded directly to the top of the stringers with epoxy (1/4") gap maximum.
What I really need to know is the original sole level OR (even better) how far up from the keel is your loaded water line ? As you CG and trim will be almost the same as mine, this will be extremely helpful.
Joel
Old 10-22-2010, 11:54 AM
Thanks guys. The coring of the sides, Im still up in the air about, I may just go with stiffeners and "box frames"
John B, that is helpful. How far is you sole above the waterline? How well does the cockpit drain?
I am trying to lighten it up a bit. Dual tanks is something I have been considering, its a pretty easy thing to do, and will allow me to adjust trim. I really do not like the idea of the bait tank sitting on the transom. I like it for fishing, but you have 2 guys standing back there rigging/fishing, 100 gallons of water, then a heavy outboard 30" further back then originally designed.
I just put 2 tanks in my 23 . . . one 55 gallon (under the console in place of the step down storage) and a 70 gallon behind the 55gallon. I'll let you know how it works when I launch.
BTW - Hermit's boat is setup perfectly . . . it's a rocket out of the hole and cruises nicely at 30mph. It's super responsive too . . . turns on a dime.
Old 10-22-2010, 01:38 PM
grgrmouse grgrmouse is offline
and my boat
friggin gorgeous....
20' Mako 175 'rude
Sacto, CA
looking for a landlocked 23'-25' Seacraft
http://classicmako.com/forum/topic.asp?TOPIC_ID=13979
Old 10-22-2010, 02:22 PM
Joel,
My sketch plan is not to scale but yes...it is an acurate tank location. I can get some measurements for you if youd like. There is also an oil tank mounted in the bilge aft of the tank.
Like Bigshrimpin said the boat performs very nice. An Etec on the back would make it perfect . I cant take credit for the layout as it was copied from Strick's 23 and various Hermco re-habs I just chose a smaller tank for my use.
1974 23SF
Old 10-22-2010, 03:27 PM
Moderator
that waterline measurement would be great.
Its fine that the sketch isn't to scale, i will scale in a some software we use. Just so long as the center of the tank is accurate.
Old 10-22-2010, 09:17 PM
Good topic and our colors are very similar! My tank is ~120 and I can get a decent measurement if needed. I believe my deck is std. height.
Old 10-23-2010, 08:02 AM
The bottom of my boot stripe is 5.5 inches above the chine. The water line at rest is 2 inches above chine. The full tub on the bracket really floats the tail end of the boat.
1974 23SF
