Old 10-20-2010, 01:13 PM
shine shine is offline
Moderator
Default 23 CC rebuild - shine
Picked up my next project boat yesterday Its a 23' CC.
Some work has already been done on this boat. The transom has been enclosed, and the stringers raised 2" . The work was really well done (all epoxy), so i will not need to rip it out. The transom enclosure has a couple hatch liners included, which was nice
The boat did not have liner, so i will need to either core the sides or make a shelf/frames to stiffen it up.
I plan to use all wood/epoxy/biax for this one. I will probably keep this boat myself, so wood is not a concern.
Since I did not have the pleasure of ripping the boat apart
I do not have measurements/locations that I will need to "re-locate" console/tank/baitwell/etc. Im hoping some of you guys can help me with these. I will post individual questions later as seperate topics, this thread I will just use to update progress.
will get better pictures next time I pull the boat out..
Old 10-20-2010, 08:33 PM
rcm rcm is offline
Default Re: 23 CC rebuild - shine
i was tryin to buy this boat. you beat me to it. you wouldnt happen to know where another one is would you? anyways. looks good so far. how do you plan on doing the baitwell in the transom?
Old 10-20-2010, 09:57 PM
Moderator
have not found another very close.
Im not sure Im going to use the baitwell in the transom, if I do ti will be a secondary well. Im figuring my weights right now. For fishing the rear well is nice, for CG issues it might be tough to make it work without moving fuel/console up too. Good luck finding another one.
Old 10-20-2010, 11:31 PM
htillman htillman is offline
I'd move the tank forward and go with a single 150 gallon tank. The batteries were originally installed in the bilge area behind the tank. They should be moved under the console which will help. In my opinion on a CC the more weight moved forward the better as my 1977 runs "bow proud". I can get some measurements but you can get most from the brochures list on this site. Good luck.
Old 10-21-2010, 11:33 AM
JohnB JohnB is offline
I am not sure what your plans are for using this boat, but when I redid mine, I put in a 150 gal tank, and with a single suzuki 4 stroke, I probably only needed 100 gallon. When you try to plane it out with 1/2 tank of gas, the gas all sloshes to the back, and you have to work it a bit.
I have never been able to burn more than 50 gals in a day.
It is probably the only thing if I had to do over I would change.
JohnB / 23' SeaCraft
Old 10-21-2010, 11:54 AM
Default Re: 23 Rebuild
I. . . When you try to plane it out with 1/2 tank of gas, the gas all sloshes to the back, and you have to work it a bit.
That's a good reason to consider installing two smaller tanks! You'd have better control of CG that way!
Old 10-21-2010, 12:21 PM
I went with a 120 Gal. Tank and that’s been working out pretty good for me.
FellowShip
Just for the Grins
Old 10-21-2010, 12:37 PM
Trayder Trayder is offline
Velvet Jones
you may not need to core the hull insides, I did my 20 without any and my current Conch 27 does not have any either. You will be very surprised how stiff the hull sides become once you tab the deck to it. On my 20 I laid in some fairing compound and then gelcoated it, on the Conch I think they hit the woven roven with a D/A and 60 grit then rolled the gel on, not pretty, but it could be if you spent some time with fairing.
Nice score by the way that boat looks like a perfect blank canvas!!
Old 10-21-2010, 04:43 PM
I hindsight, twin 60 gal would be great, but it is what it is now. When I get a 40 gal livewell in the transom full of water, 100 pounds of ice in the fish box in the floor, the 250 suzuki hanging 3 feet off the back, and a couple fishing buddies decide to sit on the transom, it can take a minute or so to get on plane. The trim tabs pretty much fix the problem.
Weight is an issue with these boats, and my goal has been to remove every pound I don't need.
Old 10-21-2010, 05:35 PM
Moderator
Thanks guys. The coring of the sides, Im still up in the air about, I may just go with stiffeners and "box frames"
John B, that is helpful. How far is you sole above the waterline? How well does the cockpit drain?
I am trying to lighten it up a bit. Dual tanks is something I have been considering, its a pretty easy thing to do, and will allow me to adjust trim. I really do not like the idea of the bait tank sitting on the transom. I like it for fishing, but you have 2 guys standing back there rigging/fishing, 100 gallons of water, then a heavy outboard 30" further back then originally designed.
