Old 08-12-2011, 11:27 PM
Default Re: 1977 seacraft cc gas tank
Kroil is probably the best penetrant commercially available.
Sorry Denny...
Whitmores is the BEST!!!!
Hard to find but it kept the Shuttle flying for 30 years!
Whitmores
See ya, Ken
Old 08-13-2011, 08:15 PM
I have a 1977 seacraft with the same gas tank - now having problems with pump ball going flat after speeding up for a few mins then slowing down . was told problem could be in feeder hose in tank - try to back off from tank - afraid to ruin connector any suggestions
Mine was in my new used tank I just put in. Not super happy after I pulled the main tank to add floatation and adjust CG with my heavy motor setup. Verified with a above deck tank and that works fine, but mine would suck the squeeze bulb flat.
Old 08-13-2011, 08:33 PM
Rainmaker Rainmaker is offline
I had issues with my tank in the past. There was a screen on the pick up tube that was getting clogged and also touching the bottom of the tank. It would suck to the bottom when there was a little debris stuck around the edges. I could run a few miles and it would suck the ball flat. I pulled the tube, removed the screen and then cut a small C in the end so that would never happen again. Has not been an issue since.
Old 08-13-2011, 11:15 PM
Fasteners that see over 1200F are a real bear to remove, and I know that Kroil works on them. Most of the shuttle never got that hot, but then again, neither do most gas tanks, so I guess Whitmore's might work for that! Do you buy it by the pail for your SeaCraft fleet? Where do you get it?
