Old 08-17-2011, 12:48 PM
Wildman Wildman is offline
Default 20ft scuppers
I have seen a picture somewhere of a guy who crossed his scupper tubes, exiting them out the back of the hull. I am wondering if this is possible without raising the floor? Without cutting the deck up?
Anybody got a link?
Old 08-19-2011, 04:14 PM
Default Re: 20ft scuppers
EI'VE got a 82 the s uppers exit the transome with a tube run from the cockpit to the transome I've nit had the boat in the water
don't know if it a problem how would they be run otherwise?
82 seacraft 20SF
Bayview Canvas
Old 08-19-2011, 07:15 PM
Run the starboard deck drain to port scupper and vice versa.
The genius of Mr. Moesly.
When standing in the starboard corner, the incoming water has to go uphill to the port deck drain to ingress. Not so easy going uphill. Simple and brilliant. Ping pong scuppers help lots as well.
Cheers,
GFS
Old 08-19-2011, 09:31 PM
Is there enough 'pitch' to run them out the back of the transom from deck level? Will they be below the waterline?
Old 08-19-2011, 10:29 PM
OilFieldMan OilFieldMan is offline
Ping pong scupper? I understand the ball plugging the drain when the water pushes it up. Simplest version of a check valve. Sounds like this is the least work for the scuppers at the water line problem. Anyone have a link to buy them?
1974 Seacraft 20' SF with 1985 Evinrude 150 VRO
1987 Seacraft 23' Scepter with 2007 250 HP Evinrude Etec
Old 08-19-2011, 10:35 PM
joshz joshz is offline
raybud
Outermostangling Charters
Old 08-19-2011, 10:36 PM
They will only work if the ball is OUT of the water the majority of the time. If there isnt enough pitch from under the deck out to the transom (or if it ends up below the water line) than its not even worth doing.
http://www.rabud.com/SCUPPER-FLYER-small.pdf
