Old 02-17-2012, 10:41 PM
csurf csurf is offline
Default Need a prop!
So the motor is on! Boat is finally coming home after 2 months. Looking for prop suggestions? Thinking 15-16" 17" pitch... ballpark? Need a good place to start any help would be great. Thanks Guys!
-Chris.
1980 23' SeaCraft
1992 16' Steiger Craft - Custom Flats Boat
The sea finds out everything you did wrong.
Old 02-18-2012, 07:22 PM
bbh57 bbh57 is offline
Im running a 13 1/4, 19 on my 23. seems to be pretty good RPM's right etc. but would like to try a 14.5x 19.
Old 02-18-2012, 07:39 PM
travisrandall travisrandall is offline
I run a 15x15 mirage with my 225 merc. 15x17 mirage when I want to play around by myself. With a t top
Old 02-25-2012, 05:11 PM
downnout downnout is offline
Default prop size
just bought a yammi 225 ox66 for my 1974 23 with no bracket, i see discussion about a factory yammi prop 17 in pitch but no diameter size. i need a prop any help???
Old 02-26-2012, 12:45 AM
Yammie SWS 14d x17p in stainless the old semi cleaver style. New s.s. models are 14-1/4.
14-1/2 x17 in the aluminum.
Semi-cleaver shape is easy to turn and gives good stern lift. They are now making the shape in a 4 blade too for more lift and grip in turns.
Borrow a couple used props from local dealer to get it right.
If you can't reach top of rpm range you may want to consider going to a 15 p. The shape of the prop is as important as the pitch in getting it right.
Good luck
