Old 08-07-2012, 12:03 AM
That would be an offer I could not refuse
Old 08-07-2012, 08:49 AM
Talking
3/4" square bars of aluminum or stainless (could use tubing if you prefer); cut the ends at appropriate angles weld on 3/16" flange plates w/countersunk mounting holes and screw in place. Give bar a little quarter round to match the soft curves of the 21 and your done...
The problem I see with this...the top is a compound angle of 5' x 39' plus (miter saw only cuts wood ) my welding skill do not include aluminum or stainless... See solution below
Terry,
I made mine out of 304 stainless sheet and bent it on a sheet metal brake we've got at work. It's very stiff, no worries about it letting go if someone grabs hold
I have plenty of the material left if you want me to throw a couple together for you, no charge. I'd need you to send me a wood template that's the right length and has the correct angle cut on each end. Or I could just bend some angle stock and you can cut it to length and bend the ears on the ends. Call or PM me if you're interested.
Dave
I will...
I won't
