Old 09-05-2012, 06:42 PM
Default Poly versus aluminum gas tanks
Has anyone heard if poly gas tanks would/could cause more condensation than aluminum? I know it's a goofy question, however I've got a friend who's boat I'm tired of fighting water in the gas and he has a poly tank. Drained it once and now four months later it's got water in the gas again. The bad part is I can't find any leaks. Thanks guys!
Old 09-05-2012, 07:09 PM
I doubt condensation is the problem. Typically aluminum or stainless would exhibit more water exchange from condensation. My guess is a leak at the fill cap...
pelican pelican is offline
find the source of the water- then your problem is solved...
i had a poly tank that was allowing water into the tank - the tank was cracked on the top...the owner of the boat,he tried a few repirs - replace fue sending unit,and swap out a hose - i had supected it was a tank - after it was removed,it was confirmed...
again,find the source of the water - it's not condensation...
Old 09-05-2012, 07:25 PM
Yeah....that's what I told him. He might want to get out the "big" check book for that. It's a two piece boat and there's no way to get the tank out or work on it without taking the top cap off. One 8" inspection plate over the fuel guage sending unit and the fuel pick up and that's it. Yowza!
Old 09-05-2012, 07:32 PM
no such thing as a tank that can't come out
i've never pulled a cap to replace a fuel system...
the deck's cut,tank's removed,and deck's glassed back down...
Old 09-05-2012, 07:57 PM
Don, you should know better then to hang out with the Bayliner, Trophy croud....
With those just cut them in half and slam a 6 gallon portable tank in!!
Old 09-05-2012, 08:37 PM
Hey I'm with you guys on this!!!! It's a Kenner (Tracker Boats) and I'm over working on this. It's not like my SeaCraft or Hewes where I'm more attached and in love!! I'm so over it, I asked him if it was fully insured!!! KaBoom!
