Old 01-16-2013, 01:10 PM
I'm with Big... No wander at all, at any speed. Straight as an arrow. I run a 225hp Yamaha two stroke outboard. It's light weight at 411 pounds. Also it is mounted about two inches above the typical transom lip. No wander at any trim level. I also have some additional weight forward due to a large fiberglass and aluminum hardtop
Old 01-16-2013, 02:41 PM
In Big John's case, I imagine the down-turned trim tabs offer some tracking assistance.
Handful, Looks like someone stole your tabs.
Nonetheless, I think the absence of some pressure in the steering pump will prove to be the primary culprit of your Sceptre's sashaying issues.
Old 01-16-2013, 04:10 PM
My wife says... I can't dance, but my boat sure can!
1974 23' Tsunami, fully refurbished, custom pilothouse, Hermco Bracket, 250 Etec
1977 23' Sceptre fully refurbished, soft top, I/O
Old 01-17-2013, 06:57 AM
If you have power assist steering on your boat then Mercury does not put a zinc torque tab on the out drive. Manual steering yes.
My Bravo doesn't have a torque tab, just a flat anode. Alphas could be different, I don't know.
Blue Heron Boat Works
Old 01-17-2013, 09:01 AM
bigeasy1 bigeasy1 is offline
I don't know either,but my Alpha came with one,and as mentioned I removed it because it wouldn't clear the larger prop.
I don't notice any difference in steering without it.
From what my mechanic says,Mercruiser also has a lower profile anode for the Alpha drive that can be used in place of the finned version when you're running a large diameter prop.
In my case it's all freshwater,and I've since gone to launching and loading daily instead of a slip,so I'm not overly concerned about electrolysis.
All this,just for a boat ride
Old 01-18-2013, 12:55 AM
floorboy floorboy is offline
Mine is better since I put hydraulic steering on it over the stock cable. But it is still all over the place when I idle back into the dock. Anything above a dead idle and it is very manageable with slight correction. But it is very easy to oversteer it.
