Old 11-26-2014, 10:30 AM
keith keith is offline
Thanks for the reply Oldfielder. He sandwiched the silicone for added seal with the gasket provided as an extra measure. I am with you, I think it is ok. He is a good mechanic. After looking through this site at all of the rotted out transoms and floors I am on high alert to all the penetrations. I would really like to avoid a restore for as long as possible. I just want to go fishing. Great idea using the flashlight at night, I will definitely do that.
He gave me the full shop manual for the outdrive so I think I am good there but it would still be nice to have the pdf. I will pm you. Thanks!
I don't think it has been really gone through since he installed it 6 years ago. It has 280 hours on it. I was going to do the impeller as soon as I get it home.
Thanks, Keith
Old 11-26-2014, 11:39 AM
pelican pelican is offline
Thanks, Keith
I gave you some good info concerning a few things : http://www.classicseacraft.com/commu...728#post232728
there's info concerning the waterpump in there,along with some general info.
follow the advice given -it WILL keep you out of trouble
the MPI motors,are very smooth,powerful and reliable ! I've used quite a few of those 5.7/5.0 MPI motors on repowers -both straight inboard and stern drive applications.
the fuel economy you will get,it will impress you !!
Old 11-26-2014, 11:56 AM
silicone:
sealing the transom assembly against the transom:
there's a seal from the factory attached to the transom plate - me,i've used black 3m 5200,a quick smear is all that's needed.silicone has no place on a boat.i've lost count of the transom assemblies I've installed...
water intrusion:
stern drives - look where the cut out is,for the transom assembly - this area is often overlooked - this area needs to be sealed - if it's a wood core.seal it with EPOXY,not the cheap porous polyester resin - this is often overlooked...
3m 5200 :
the inexperienced will tell you it's permenant - it's not !
few things I noticed in the pictures :
nylon/plastic thru hulls -I see one,port side -you need to be careful with these - plastic will become brittle and break/crack - not a good thing...
prop - looks to be the standard aluminum prop - looks like it's been run through the mud or sand - you may want to send that in for reconditioning
lenco electric tabs - seen quite a few problems with those and sea water intrusion
side notes:
additional bilge pump - allways good idea to install a second bilge pump -wire this to a seperate battery than the other pump - feed power to the auto float switch from the battery terminal behind the battery switch though a waterproof in inline fuse to the float switch lead.
separate thru hull,and hosing
high bilge water alarm - install one !!
Old 11-26-2014, 08:09 PM
FLexpat FLexpat is offline
Probably the biggest thing is to make sure you have power to the bilge pump. Boats at the dock don't usually get a huge leak - mostly a small one that drains the battery as the bilge pump cycles. If the bat drains because of a slow leak, the boat slowly sinks. If you are not on shore power then get a solar panel on it and make sure you don't accidentally turn off power to the pumps.
The weird place on my 23 that had a slow leak was the scupper. The port side brass tube had corroded through but you couldn't tell except for the slow trickle in a flashlight beam after crawling into the transom and laying on top of the motor. The wood backing block was jello from the leak - it even leaked in from rain on the deck while sitting on the trailer. There are more threads here about scupper issues than I can count and 4x as many opinions.
The good news is that after it has been in for a while you quit worrying as much...
Old 11-27-2014, 11:25 PM
About the silicone. I wasn't too excited to hear it but it is sandwiched between the outdrive and the transom so I thought it could be ok. I could take it off and re-seal it. Do you think it is necessary right away?
Do you guys have any advice for resealing any bolts that may be in the transom, like on the swim platform? Should I go around them with something or take them off and make sure there isn't any damage? I have read on here that holes should be overdrilled, epoxied, and then drilled to desired pilot hole.
Thanks,
Keith
Here's a good summary of the various marine sealants available that you might find useful.
Old 11-29-2014, 11:47 AM
Pelican,
Thanks a lot for your recommendations! It is nice to have access to people so knowledgeable on this site. I replied to some of your comments below.
Thanks, Keith
Originally Posted by pelican View Post
silicone:
water intrusion:
Not sure what you mean by this. Are you talking about the bottom of the transom on the inside or the outdrive cut out?
Are you talking about the transducers? If so, I'm thinking of removing them and installing an in hull one instead. Not sure what to do about water temperature yet though...
It is a brand new stainless prop. I think it was bad lighting when I took the pictures.
Ok. I was going to remove these bolts and reseal them or give the west method a try.
side notes:
Are you saying to make another penetration for the second bilge pump? There are currently two installed but they go out of the same port. Neither are on a float but I plan to install float activated bilges asap.
Good call. Will do.
Old 11-29-2014, 08:57 PM
Pelican,
Thanks, Keith
Good call. Will do.
transom cut out - look inside the boat - it's where the transom was cut out to allow the transom assembly to fit...
thu hull - it's on the port side - looks like maybe a bilge pump outfall ?? it looks like it's plastic...
that other set of pictures - the prop was black - looked like a standard aluminum prop
lenco trim tabs - the actuators often fail - due to water intrusion -actuators not the tab screws
bilge pumps - NEVER share thu hulls !! separate thu hull for bilge pump exits !! smooth hose as well !!
Old 11-29-2014, 10:24 PM
look at this picture:
look at prop - it's black,and it's an aluminum prop - notice the edges of the blades ??
look below hull vent - see the white thru hull ???
Old 11-30-2014, 09:14 PM
Got it. That was from an old picture he sent me before I went to buy it. Yeah, I can see the aluminum prop.
I do see the bilge thru hull and it does look plastic. I will check it out and let you know.
Thanks
Old 12-10-2014, 01:47 AM
Keith,
You got tons of great replies from everyone. I am another that will 2nd using 3M 5200. I am in Idaho so another West Coaster and a Lot colder than SF bay.
Some of the things to do on this side of the coast...as well as the NE part of the country. The water temp is wayyyy colder here.
SO I...
Have 3 bilge Pumps in my boat.. Some will say overkill, but... Florida water wont kill you in 60 mins or less like here.
Every Bolt on the outside of the hull that is under the water line should be sealed good...I prefer again 3M 5200...just me.
Would recommed going thru the Outdirve, Has the Gimbel Bearing been done, seals and Water pump.
If you were really concerned about not having to do maitence on that boat again... You can pull the Engine and Outdrive in less than an Hour. Install New Gaskets and 3M 5200 and reseal it up. Then as the boat owner you know exactly what has been done. Over the years i have learned, don't take someones word for it unless you did it yourself, you don't know.
I did not look to see if that was a Closed Cooling system or not..I would assume Closed. If that's the case don't foreget the semi-annual maintenance on that bugger.
The 23' Hull is Amazing for our side of the country... You could take 2 days, get thru everything and know without a doubt she is in tip top shape and then You Yourself can start keeping track of Maitence.
Keep a Log of what and when you do things. It will help down the road.
Happy boating my friend.
Robert
