Old 02-13-2018, 01:09 AM
Wac3riv Wac3riv is offline
Thanks ken
Old 02-13-2018, 10:58 AM
Try wet sanding a section with 1200 grit, look around your area to find some "Aqua Buff" compound.... It is good stuff.
That gelcoat is thicker then you think !
My son does that for a living... You would be surprised at the results..
He wet sanded a section on the red 1968 27 SeaMaster about 5 years ago
and it is still shining !! I will get a pic in the morning for you...
Cheaper and easier over painting or re-gelin'..
Ditto! Mine came out beautifully!
Old 02-13-2018, 11:33 AM
NoBones is correct! My neighbor turned me on the the Aqua Buff, stuff is really good. I would start with the 1000 then maybe move up to the 2000 to finish, here's what you are looking for. If you go the fine sandpaper first you may only need the 2000. Good luck and Aleve works well for the sore muscles.
https://www.ebay.com/itm/Aqua-Buff-1...oAAOSwA3dYlhdw
Old 02-13-2018, 01:03 PM
Here ya go....
This test area was done at least 5 years ago. Has not been touched since !
Old 02-13-2018, 01:30 PM
Wet sanding a twenty by hand is very doable. Factory gel coat, measured in mil’s, is normally about a dime thick. Probably thicker on older models. Unless you want a different color, you’ll be amazed at how the oxidation can be removed up to 100%. That yellow is classic and after years of detail experience always remember one thing:
Cars are painted.
Boats are gel coated.
Just go bump your dock, or ask me how I know.
Vezo.
Old 02-13-2018, 02:46 PM
Just for grins....here's a cross section of the transom skin off a 1972 23' I/O CC. The glass is 1/4" thick including the red gel coat. And let me tell you that stuff gets on everything when you grind it!!
Old 02-13-2018, 04:41 PM
The deck is a little brittle so i think the new layer of gel coat will be great for the longevity of the boat.. the color sanding on the hull should come up nice..
Old 02-13-2018, 04:42 PM
Old 02-13-2018, 05:01 PM
DA sanders work well for this job.
Old 02-14-2018, 05:24 AM
IMHO, if you're sanding something that potentially had wax at some point, use wax remover first. That will buff right out
