Old 10-30-2022, 09:46 AM
wgscott329
Thanks for posting your project here on CSC. Looks like you are well on your way....If it turns out anything like that beautiful 23 you re did it will be a success. Not sure if you have ever had the pleasure of driving the 25 yet?
cdavisdb (Conner) has the most experience of us all with the 25... he had one for years and made several Bahamas trips. It's a great ride in a head sea as are all seacrafts. The 25 will turn into a sharp bank like a F16 fighter jet. It's a little unnerving the first time you try it but don't worry it will not flip over... you could almost reach out and touch the water if you have long arms. I had a 25 with a 350 duo prop. The thing I did not like about the boat is that it is very sensitive once on plane. just having people moving about on the boat is enough to change the attitude while at speed and you may reach for the trim tabs. It was suggested above that auto trim tabs would be a good idea. We are very much looking forward to this project as it's not been done before here. There was a 25 center console up in the North east Bigshrimpin may remember it better then I do and have some input...Thanks for posting If you load your pic to a desk top they should load up right otherwise I can flip them over for you..
Old 10-30-2022, 02:32 PM
wgscott329 wgscott329 is offline
Y'all want me to include the 23 rebuild here or have another thread for it? Just getting around to fixing the cracked keel on the 23. Next is stringers.
Old 10-30-2022, 02:37 PM
Thanks for the compliment Strick! I hope it turns out as good as the first 23, I think it may even turn out better! Got the new transom for the 25 cut out and almost ready to be installed. Cool pic of the of the 25 transom cutout overlayed on the 23 transom.
Old 10-30-2022, 06:07 PM
wgscott329
I remember the 25 CC conversion that was on the Cape, well Bourne I believe (not intending to start a debate about what is and is not "the Cape"). Seemed to be fairly dialed in but my memory is fading so maybe Bigshrimpin can chime in with a recollection. The auto tabs also seem like a great retrofit to deal with the significant dead rise. I've wondered how twin 200's, transom mounted but spaced fairly far apart, would do? Less tender at slow speeds and on plane?
Old 10-30-2022, 08:27 PM
Post away...interested about the cracked Keel...did you have the original wood keel still in the boat? freezing temps have been blamed for expanding and contacting of the water logged wood keel in the past.
Old 10-30-2022, 09:39 PM
Yes!!! There's a reason Potter never produced a 25' CC. He told me one day " We just couldn't get it right"
You better think this conversion idea thoroughly..
My understanding is that the reason it didn’t behave right is that Moesly intended for it to be built with the ballast system he had designed (and patented!).
https://moeslyseacraft.weebly.com/up...st-3503358.pdf
But Potter never built it with the ballast system! The comments regarding the 25’s sensitivity to CG location and trim tab use imply that a ballast system might very well have helped alleviate some of the reported handling problems. And the additional bulkheads required for ballast tanks might have also provided additional stiffness to the the hull!
Perhaps adding some rubber bladder tanks under the deck which can be filled and drained without the use of vents would allow you to adjust the CG location on this hull while underway like Carl Moesly intended!
Old 10-30-2022, 10:03 PM
Get post Denny!
This dead rise on the 25' will never be a good planning type hull.. I would like to hear more from Connor he is experienced. As is, without that forward weight , traveling in a heavy following sea, or entering an inlet with a incoming tide, would be nightmare. Getting from Point A to Ponit B would require a ZigZag course....
Old 10-30-2022, 10:44 PM
Richie Carvalho owned this 25 and before Big Fluke.
https://www.chapmanfuneral.com/obitu...?obId=20630303
From BigFluke:
http://www.classicseacraft.com/commu...t=20269&page=4
Originally Posted by bigfluke View Post
Blackfin,
I did buy the SeaCraft 25' in Massachusetts that wss converted to a center console by a commercial fisherman. He really knew what he was doing: removing the foredeck cabin and building a fishbox from the footwell to the forward end of the v-berth inner liner shifted the lcg forward and kept the vcg as low as possible. From what I understand the fishbox was always full of ice or fish so his set up is much as Moesly envisioned with his ballasting system. He also moved the helm aft a bit which is a lot more comfortable then the original helm about 2' more forward. With the big block sterndrive giving it adequate stern weight, it runs much better than the other two SeaCraft 25s I have that were originally rigged with a smal block sterndrive and the other that I retrofitted with a single large outboard on a porta-bracket. Excellent seakeeping out to about 22 knots. Above that speed needs to be driven very attentively and with constant tab adjustment to keep upright in rough water or it will loll.
Old 10-30-2022, 11:16 PM
I floated my 25 without power a few times (and broke Strick's 25 once) . . . The hull definitely NEEDS weight. Strick scared the Sh#t out of me the first time he banked the boat at speed.
I've been told the hull needs weight (down low) to sit right in the water and not just weight forward. I got to discuss the 25 hull with a former Navatek employee that worked on the 25 project for 4 years. He lives in MA now (his wife still works for my employer). He wrote Matlab code for measuring the ride in quantifiable numbers, put thousands of hours on the hulls and talked in depth about the different configurations at Navatek.
"adequate stern weight" was something he mentioned . . . Steven Loui also used those words in a post.
"With the big block sterndrive giving it adequate stern weight, it runs much better than the other two SeaCraft 25s I have that were originally rigged with a smal block sterndrive and the other that I retrofitted with a single large outboard on a porta-bracket"
Connor and other owners might be able to shed light on their configurations.
Old 10-30-2022, 11:55 PM
I'm pretty sure you don't need long arms That ride was eye opening. Do you still have pics on where you reinforced the hull in the front? I seem to remember someone cracked their hull by front stringer or bulkhead
