Old 01-16-2003, 12:44 PM
tangofniro tangofniro is offline
Default HP on a 20ft CC
Does anyone know what the min and max hp on a 1970
cc. One more thing, at one time it was a cuddy but was changed to a cc open fisherman. Thanks for all of you help.
W. Smith
Old 01-16-2003, 02:06 PM
Scott Scott is offline
Default Re: HP on a 20ft CC
Tango ....Welcome
I'm not sure about the HP for that model but here is a Start
I dont think the rating would have changed all that much (info is based in 1978 )
Old 01-16-2003, 05:22 PM
Endeavour Endeavour is offline
Tango, if you're worried about maxing out HP I think you'll max out on weight before HP. I have a 150c Yam on my '71 and I can't imagine anything heavier, I tried a 130 honda 4 stroke but would have had to re-build transom or add a gil bracket. I've got about 4" of freeboard remaining at the transom which ain't much. Min HP to get up: guessing 90hp on the newer engines but that would be like molasses. I get 6-8 gph at cruise 32 mph, top around 40 mph down hill, wind from behind...
Old 01-16-2003, 08:02 PM
SEAFARI SEAFARI is offline
Tango,
Dont go more than 415lbs,the Honda is way
too heavy for the 20's. The 140 Suzy or
Johnson 4 stroke is a good choice for fuel
savings. A small block V6 older carbed Yams like
the 200 Pro-V only weigh 415 lbs. The newer
Fichts to 175 are light in weight also if
you can trust them?
chris
Old 01-16-2003, 09:41 PM
BJGreen BJGreen is offline
My brother-in-law's family has a 1969 yellow seacraft that originally had an 85 evinrude on it and it allegedly ran great even with the 85- it now has a 140 evinrude on it, and man is it fast. Does 40mph+. The 140 is a good choice as it is still based on OMC's v4 block and you get the most bang for the weight, and the buck too for that matter.
Old 01-17-2003, 08:37 PM
Does any of the hp rating change when adding a gil bracket to the transon? I am closing in the I/O hole and will then be adding the bracket.
Thanks for everybody's help.
