Old 02-28-2014, 07:39 PM
Originally Posted by dave2400 View Post
ops ops my boob i should have sead my outboard is a 125 force with a 20inch shaft sorry a.t.b dave
The last of the V8 interceptors.
Old 03-01-2014, 11:44 AM
...from looking at the brackets on here that the likes off outhers on here have made it looks thay slant from the transom to transom what is that slant allso how deep is the v in the bottom....
The geometry of the bracket will be dictated by the geometry of your boat, so it may not be the same as for a Seacraft. For the fore and aft angles, measure the angle between your keel and transom. For the deadrise, you will also want to match your hull.
You can use plywood and glass construction if you like, but you really should use epoxy resin if you go that route. If you use strick's one-off mould method, you can use less expensive polyester resin, you'll have much less fairing to make it look professionally done, and it will be lighter and stronger. The method is tried and true, whereas the plywood/glass approach is a reinvention of the wheel unless you have a professionally designed solution.
Dave
Blue Heron Boat Works
Old 03-01-2014, 03:26 PM
dave2400 dave2400 is offline
Smile
Dave
dave it was not the transom angles i was onabout but the the angle from front to to back off the bracket i take onboard what you say about the geomery of boats not being the same but like i sead i reply to your last post if you look a the link in the reply to me by mr mcgillcardy you will sea there is not a lot off deferance in the hunt18 and the seacraft infact the seacraft 18 might be the hunt 18 sister
Old 03-01-2014, 05:49 PM
hi thanks for that i take onboard what you say about the shape and floatation but what about the 1inch per foot off setback is that ontop of fitting the bracket 2inch above the bottom off the hull or do you fit it 2inch above the bottom off the hull and then 1inch per foot off setback a.t.b dave
Dave, I think the 1"/foot of setback is the often used rule of thumb for height of the motors anti ventilation plate above the keel. In my experience, it needs to be more than that. The engine makers say that the top of AV plate needs to be above the water when you're up on plane with motor trimmed out as far as you normally run. My bracket has a 2.5' setback, so that rule of thumb says my AV plate should be 2.5" above keel. However as you can see in attached pic, it's 3.25" above the metal rail extending aft from keel. I have since raised it to 4.25" and AV plate is STILL underwater, so it needs to come up about another inch! Therefore in my own experience that trade factor would seem to be about 5.25"/2.5' or roughly 2" per foot of setback!
Old 03-02-2014, 03:24 PM
thanks bushwacker that makes it mutch clearer dave2400
