Old 02-28-2014, 02:15 PM
dave2400 dave2400 is offline
Originally Posted by hermco View Post
You can build the bracket with any shape. It will not be in the water when the boat is on plane. The larger the area that is submerged at rest will determine how much displacement or floatation it will provide if that is an issue. The first bracket designs were just welded tubing and a plate to mount the motor.
hi thanks for that i take onboard what you say about the shape and floatation but what about the 1inch per foot off setback is that ontop of fitting the bracket 2inch above the bottom off the hull or do you fit it 2inch above the bottom off the hull and then 1inch per foot off setback a.t.b dave
