Old 08-21-2019, 04:47 PM
So take them off and I have a bunch of holes in my freshly painted boat? Man I'm not ready to consider it yet! I do plan on going with a thru hull transducer in the future
But now what to do ????
Old 08-21-2019, 06:09 PM
Well, i can understand that but you asked for the advice and you have gotten several responses recommending the tabs to be moved. I would heed the advice. A few 1/8" holes are an easy repair, even on a new paint job.
Good Luck Jorge with your decision.
Old 08-21-2019, 10:54 PM
I guess Saturday I'll have something to do
Old 08-22-2019, 12:10 AM
Mount them on the outside planing surface. period.
Your transducer should be mounted like this: Middle of the planing surface, away from chines or turbulence-causing hull shape, and for 3-in-1, tripleshot, totalscan, or sidescan transducers the entire emitting surface must be below the hull on the inside edge. The emitter sends out it's acoustic signal at an 87 degree angle. If it's not below the hull, it's in the air when on plane. On mine, the emitter is nearly hemispherical when seen from directly behind. I can hold sidescan imaging at 30 knots because of how the 'ducer is mounted. It does throw a lot of spray, though.
Throwing the towel on this placement as well !!!
Transducers need to be as close to center on the keel as possible..
Roll and pitch will throw the angle of deflection WAY off like the one
pictured...
Just read the manuals that come with these devices, it is not rocket science
for Pete's sake..
You will have to excuse the late post ! Just got home from a Ted Nugent
concert in Daytona tonight....
No "Feel the Bern" bumper stickers there !!!
Rock On !
Old 08-22-2019, 08:44 AM
This is where mine ended up. Very responsive.
Old 08-22-2019, 11:03 AM
lelandtampa lelandtampa is offline
Bennet will swap out your actuators to an external hose style at no charge if you need them
Old 08-22-2019, 01:00 PM
Rock On !
Wang dang a-sweeeeet poontang!!
Old 08-22-2019, 01:15 PM
Dog eat dog is the most underrated Nugent tune.
Old 08-23-2019, 04:34 PM
As much as it pains me I relocated the trim tabs today. The beast will be getting to the one behind the bait well but I may have a”solution” for getting at it
