Old 02-19-2021, 09:55 PM
Boonie23 Boonie23 is offline
I know everybody seems to be reluctant to transom R&R from the outside but I think you get a much better result. Trying to save a 40+ year old outer skin with 50 patched holes in it is not a great foundation to start with IMHO.
What do you guys do about the HIN when you do the transom from the outside? Owner before me did mine from the outside but left the top right corner of the outer skin to save the HIN. Can I cut it off and have someone restamp the transom? My first build so thanks in advance.
Old 02-19-2021, 10:47 PM
I use an engraver between the primer and paint stages...
Old 02-19-2021, 11:00 PM
Ah great thank you for the help!
Old 02-28-2021, 12:00 AM
dginge dginge is offline
Very true. Start clean.
Old 03-19-2021, 09:45 PM
Photo dump to catch up to speed... IF ANYONE KNOWS HOW TO ROTATE PICS, IM ALL EARS!!
Kinda hard to tell what going on but had to grind a bunch of blisters out from under the wet stringers. Added a couple 1700s
Old 03-19-2021, 09:52 PM
Bulkheads/water tank and fishbox...
Old 03-19-2021, 09:59 PM
Stringers in, will get capped when i figure out where any notches need to go in... 2" h80 w 4x1700 each side. Ran out on the end so had to puzzle piece some 1" corecell in...
Old 03-19-2021, 11:17 PM
steel686 steel686 is offline
Top of iPhone from 12 o’clock to 9 o’clock worked for me. Looks great as usual.
Old 03-20-2021, 09:33 AM
TMala TMala is offline
Looking great! Im following along closely always a lot to learn!
Old 03-20-2021, 07:47 PM
I can rotate them but they might be out of order..have to down load to my computer then re up load to the site...this seems to be a problem with phone up loads..Nice work as usual and enjoy your clean refurbs.
