  #31
Old 05-15-2009, 10:09 PM
small45 small45 is offline
Default Re: 1975 18' rebuild
it's hard to tell, but what i did was cabosil and screw the floor substrate(1/2" treated and dried ac plywood)down to the raised stringers and the ledger that i glassed to the hull sides. also i added a stiff knee from the keel stringer to the transom and the floor.
then i laid down two layers so far of 1708 on the substrate that i turned up about 2" onto the hull sides. i'm hoping this will add some rigidity the boat.
next i finished cutting the remains of the old floor from the liner and then cut the difference out for the amount that i raised the floor. (that was a real pita...i did that several times before i even got close)
almost forgot, while i had the liner out on the floor, i turned it over and cut out the anchor box. this was mainly so i could get at the coring of the forward cap area for repairs, but also because the original box was tiney at best. also while upside down, i cut out the rotten coring on the stearn boxes and added several layers of 1708 instead.
and now for the part that i can't seem to figure out...when i installed the liner/cap, it seems that the hull is about 5/8" shorter in overall length than the cap is! i realize that if the hull spread in width, that it could cause the reduction in length...but if that were the case, it seems like i would have had trouble installing the cap. but, it went back on with minimal effort. hey, at least i didn't come up with more hull than liner/cap!
Old 05-25-2009, 11:03 PM
made some headway on glassing the cap to the hull. i decided to just cut off the overhang of the cap. since the the hull sides and cap had over two hundred old screw holes any way, i thought it might be better to glass the cap/hull conection. i ground out all the old gel coaton both pieces(bigger job than i had anticipated) used two layers of 3" woevn tape to make the connection. it seems to be fairly sturdy at this point.
also got a start on the remainder of the transon encloser. it is a combo 12gal(ish) baitwell/cooler/seat for the kid. the main stucter for the tank is the old in floor baitwell that i did some chainsaw art on
two things i am unsure of
1. how thick is safe to build up fiaring mud without reinforcement?
2. what should i use to fill the small dings and such that will be below the water line?
thanks
Old 05-26-2009, 07:26 PM
There are a ton of different things you can use or get recomend to use. I had really good success with these 2.
I used this alot and some is over and 1.5 inches thick. I like it becuase it already has fiberglass hair mixed in.
http://resurfacesolutions.com/pc-35-...filler-qt.aspx
For the fair below the water line, you can use Quick Fair. Its Pricey but I think others will agree it works out really nice and its epoxy so you dont have to worry about the water.
http://www.systemthree.com/p_st_quikfair.asp
36' Yellowfin
1972 20' seacraft 140 suzuki
Old 06-21-2009, 11:23 PM
a little progress...i'm Very slow with my body work. especially since i decided to get rid of the two piece look on the cap...i've never really liked that about the 18's
Old 06-21-2009, 11:35 PM
you can see in this pic that i cut out the tiny anchor storage liner that was factory. i gain about 2.5 times the space this way.
here is a shot of my scuppers from the rear. they are 3 and 1/8" above the original drains...3/4" raised deck plus no contoured splash well. i molded them out of a piece of oak interior hand rail i had in the shop
Old 06-22-2009, 12:58 AM
I'll bet you are glad to finally have paint on the boat
What kind of bracket is that you are putting on it?
Old 06-22-2009, 11:37 PM
yeah...there's nothing like fresh paint to show all the flaws in my fairing job
the bracket is a HERMCO
Old 06-23-2009, 03:54 PM
thanks
I have used a product called Ultra-Fair and it is a epoxy resin 1:1 You can putty up to one inch thick according to the manufacture (Adtech). I like this product better than the Quick Fair. Just my opinion.
Old 07-09-2009, 11:03 PM
getting closer
[image]http://i349.photobucket.com/albums/q394/small45/DSC00309[/image]
and the part i've dreaded the most
Old 07-19-2009, 08:51 PM
got her in the water for about an hour this afternoon
