  #61
Old 02-19-2018, 03:58 PM
Awesome
1974 23SF
Old 02-19-2018, 07:55 PM
Originally Posted by ReelTherapy View Post
What’s the make of the Boozy Quest? She’s a beast!
Its actually booTy, but that would be a fitting nickname haha! Its a 56' DMR made in Maine. We think DMR stands for "Didnt Make it Right", but yes total tank. A friend of mine bought it after the 04 hurricanes after it destroyed all the other boats in the marina. My dad and i put the 2 hardtops and flybridge on it in 09-10. Used to be a lobster boat, then converted to a ferry in the bahamas, then was a treasure boat when the hurricanes hit. 14hours to Walkers isnt so bad at night. With the proper supplies...
Old 02-20-2018, 05:37 AM
That's really nice!
Old 02-28-2018, 09:32 PM
Got some hi build on.. Nice to be all one color again. Chine down (or up?) is some immersion rated epoxy i had a bunch of so i rolled it on. Sides are awlgrip... Dont mind the runs
Untitled by dirtwheelsfl, on Flickr
We will see how these scuppers work
Old 03-01-2018, 12:35 PM
ReelTherapy ReelTherapy is offline
Man you do some clean work! Will the scuppers have a flap of any kind or just remain open?
Old 03-02-2018, 01:20 PM
Just open for now. Been on some bigger boats with a similar setup and they worked pretty sweet. Also the holes match the OD of a tennis ball so plugs wont be hard to find...
Old 03-13-2018, 09:06 PM
Not much of a visual difference but theres ALOT of hours before this 545 got sprayed today. Goal is to have bottom and sides painted this weekend
Heres the tow eye. I took a length of 1.25"? sched80 pvc and filled it with thickened epoxy/glass and bedded it vertically in the stem, then heavily glassed it in. Drilled some holes on either side of that, and took a piece of clay about 1" diameter and wrapped it around the glassed pipe and out thru the holes, then glassed around the clay on the inside. Afterward the clay got melted out with a torch and were left with an all glass wraparound hole. Got a few layers of cloth inside it as well afterward...
Old 03-14-2018, 10:32 PM
RoomToMove RoomToMove is offline
Awesome work. I like the big boat scuppers. Were did you get your foam for the stringer's? I can't find 2" divinycell.
Old 03-15-2018, 12:28 PM
Cutoff pieces from a friend at a local custom builder. Not sure where youre at but just ask around. Most shops would rather turn scrap foam into new saw blades or light bulbs than let it sit around taking up space...
Old 03-18-2018, 06:14 PM
Between the perfect weather and st pattys i somehow managed to get some topcoat sprayed this weeknd! Cant wait to pull her into the sun for the money shot
