  #71
Old 10-11-2007, 11:23 AM
Bobv Bobv is offline
Default Re: A New Boat to Check Out
Here are a few progress pictures.
The teak top and steering pod has been fabricated for the console.
A teak trim strip has been added to the lower edge on the inside of the cap.
Console primed.
Applying the first coat of epoxy to the top.
The boat has been moved back outside to finish fairng the keel after some minor repair.
The inside is ready for finish primer.
Old 10-11-2007, 06:52 PM
This is going to be an "A+" boat when your done!! Keep the photos coming!
How many gallons did you figure the live well will be?
Lloyd
Old 10-11-2007, 09:35 PM
dljohn69 dljohn69 is offline
Looking Great! Please keep the pics coming you and Strick are doing some terrific work!
Old 10-11-2007, 11:35 PM
Guest
Posts: n/a
where in savannah is this work being done? id like to check the boat out one day
Old 10-13-2007, 03:09 AM
shorty shorty is offline
hi there look like you got sume work i have a 23 cc 1977 the center console is same is mine wath or you doing with your hatch onder console thahk you
Old 01-18-2008, 01:45 PM
A bit more progress. The console is taking a while, but it is ready for paint, except for where it will be glassed to the floor.
Holes are prepared for the motor controls as well as for electronics in the roll up dash. The channel locks will be replaced by an electric actuator to hold up the dash.
The hole below the top is for my bank of storage drawers. They are mounted in a box that can be completely removed if necessary.
Some of my switches will be in a plate mounted under the end of the steering pod.
Battery switch is trial fit into the mounting plate.
Finally, the hull is about ready to paint. The plan is to paint below the spray rail first, place it on the trailer, and move it to an inside location to paint the rest.
Happy New Year!
Old 01-18-2008, 03:08 PM
other tom other tom is offline
My friend, you and your shop are doing an outstanding (repeat "outstanding") job on this project. Absolutely no corners have been cut. You're using the best materials and taking the time to do it to perfection. Usually you only see this type of work in high end custom shops that cater to the one-off crowd that doesn't ask about the cost. Some really good ideas in this thread - it ought to be required reading for anyone contemplating a small CC rebuild.
I assume the console pod and teak cap trim will be "brightwork" finished. Awesome!
Old 01-18-2008, 03:12 PM
This will be the 23' that all other redo's get measured against
Old 01-18-2008, 04:34 PM
something tells me that these guys have seen a gallon (or thousand) of epoxy before......cool to see what experienced craftsmen and some imagination can do. Mr. Ikan, good thing its not a 20' ("....get measured against"). More boat porn!
Old 01-18-2008, 10:30 PM
joey joey is offline
Killer! Beautiful work.... Roy Merritt would be proud!
