  #71
Old 10-11-2021, 01:20 PM
x2! Nice disposition
I agree, nice job! Sceptres and a big single work well
Old 10-11-2021, 07:55 PM
PackRat PackRat is offline
Let us see some Teak on that helm station & the"Gucci Stamp" will definitely be in order! Great job sir.....
Sneek peek on teak accents…
Old 01-22-2022, 05:13 PM
Little jobs until the cold weather passes- 16 deg this morning…
Window dressing for the anchor locker divider in the cabin from recycled teak / old swim platform.
Old 01-24-2022, 11:14 AM
Nice job on that... how'd you cut it?
Old 01-24-2022, 06:31 PM
Would like to have cut it on cnc router but went with what I have at home. Just printed half at full scale, traced on teak, then cut close with a jig saw. Then came behind with belt sander/ sanding disc / sanding drums to clean it up.
Old 02-01-2022, 01:39 AM
Have a flush trim bit? Once you have a pattern like 1/4” mdf you can crank them out.
If not pm me.., I have.
Btw teak looks good. Using petit flagship?
Old 02-02-2022, 03:46 PM
I know what you mean but this was just a one-off on recycled scrap teak that was run through a planer to get rid of weathered bit. Pieces were only slightly larger that the part I wanted so had to split down the center and have the glue joint.
Used west system/ 207 hardener, couple coats, and a couple coats of clear awlgrip. Would do more coats if in the weather but emblem will be in cabin. Chairs were done same way but three coats of epoxy and 5-6 coats of clear.
Old 02-19-2022, 02:34 PM
Small 30 in wide rocket launcher for cockpit.
Old 02-19-2022, 02:36 PM
Painted
Old 07-19-2022, 09:19 PM
Finally recorded some numbers on performance:
Average of 2 runs with/against current/wind
Suzuki DF300B (duo-prop):
RPM Speed GPH NM/Gal
(knots)
3000 16.0 6.6 2.5
3600 25.1 8.6 3.0
4000 28.4 11.0 2.5
4500 32.5 13.9 2.3
5500 41.0 24.2 1.7
5700 42.5 26.0 1.6
Probably had a little more RPM to squeeze out with trim but thats where I cut it off.
Just a little under what dealer reported during initial trial.
Motor seems to like the 3600/max efficiency speed - loafing.
Curious how this compares to other 300 HP numbers with single prop if anyone can provide those.
