  #81
Old 06-05-2017, 10:07 AM
captbone captbone is offline
How does it compare to the 2.4 liter 2 stroke? Any regrets at this stage? How does it do with a heavy load?
Old 06-05-2017, 10:25 AM
Nice performance numbers!
What do you figure is the fuel burn difference from the 175?
Old 06-05-2017, 12:07 PM
I installed a square smartcraft system monitor gauge.
Fuel burn with 2 people/full tank and gear (raft, survival suits, fishing gear, 125lbs of ice) 4600rpm is 9gph @ 30/31mph. 4600 is the happy cruise in light chop. In slop it does nice 3800/4000 = 24/25 mph roughly 6.5gph. At low speeds this engine is more efficient than the 2.4L 175.
I'm super happy. This is perfect for my needs. If I had to carry bigger loads regularly or wanted more speed, then I would suggest a bigger engine.
Old 06-12-2017, 08:39 AM
Great numbers but 6.5mpg doesnt seem possible. Maybe 3.2mpg?
https://www.mercurymarine.com/en/us/...units=imperial
Old 06-12-2017, 09:11 AM
thanks CB - that was a typo. 6.5 GPH is what is should be . . . made the correction. fuel burn and speed is nearly identical to the sailfish 220 pdf.
Old 06-12-2017, 10:05 AM
I am thrilled your set up works as expected. Nice package all around for simplicity, affordability, economy and performance. I would expect that your engine rigged out the door is 50% of what a 250hp Yamaha repower would cost.
Old 06-12-2017, 10:48 AM
NO doubt!!!
Old 06-12-2017, 12:23 PM
Default Sent PM to Bigshrimpin
Bigshrimpin-
Hi. Sent you a PM as a followup to an old discussion.
Thanks
Old 06-12-2017, 04:58 PM
Terry - pm replied . . . Sent you 2 messages
Old 06-18-2017, 02:12 PM
Tried a powertech 15P four blade OFS and lost 3.5 - 4mph on the top end . . . could only turn 5250rpm @ 35.5mph. 15p enertia is WAY better. Terry the 17P is packaged up and will go out tomorrow.
