Old 06-03-2003, 02:25 PM
Mark Mark is offline
Default Re: What's causing the boat to list?
"At around 45 mph, the boat dives to port and almost seems to want to roll over. Very Scary"
AGREED! [img]images/icons/shocked.gif[/img]
Old 06-03-2003, 02:45 PM
Sounds differant.. What size motor and what is the rotation? It sounds like the fuel tank is helping to keep this from happening and as you burn fuel the boat gets lighter and it wants to roll. Have you adjusted the anti hook fin on the lower unit?, is the motor straight on the stern(up and down). Check the hull too. you may have a cup in it .. find a long straight egde and place it in the hull and look for cups. Motor too high?.. more input!!!1
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 06-03-2003, 03:28 PM
TUGBOAT TUGBOAT is offline
and thats with a single tab down to compensate
Holy Mackeral ! Looks like pipes has bout' got everything covered,I'd also say cupped.Fuel tank can't really shift,But a baffle can break allowing the fuel to go on one side.?.
Kinda remember My ol' girl(20 MA) listing a lil to port,trim tabs took care of it if "HOOVER" wasn't aboard.Dog biscuit to the starboard bow & Instant ballast !
Scream'n Reels' [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 06-03-2003, 04:35 PM
Eric McNiff Eric McNiff is offline
Hey Pipe - where is the anti hook fin? I get a slight list to port when running around cruising speed - I assume it is from the rotation of the prop.
Eric
My wife does not care for the 2 boat theory
Old 06-03-2003, 06:38 PM
Jason LaVey Jason LaVey is offline
Pipe Dreams, thanks...I've got a 1998 Merc 175 Offshore, with a four blade stanless prop. My mechanic buddy said to adjust the fin if the wheel/boat pulls to one direction. This thing literally dives to port. If the hull has a "cup" in it, what could cause it and how do I fix it?
Capt Brad, I had two healty size people sitting on the starboard side and it didn't quite cure the problem. At slower speed its more managable, but when I have 30 miles to run, I gotta move.
Mark ...scary ain't the word
[ June 03, 2003, 05:41 PM: Message edited by: 84 SeaCraft ]
I support something, but I can't remember what???
Old 06-04-2003, 01:31 AM
Default What's causing the boat to list?
Hey all, I put up a post a while back about my 20 MA listing to port while underway. After I ironed out the bugs with the Bennett trim tabs, it seemed to help. But the problem is back and seems to be worse. At around 45 mph, the boat dives to port and almost seems to want to roll over. Very Scary, and thats with a single tab down to compensate. And the problem seems to get worse as the gas tank begins to empty. Could the tank have shifted? Any ideas, cause I'm out of them?
Old 06-04-2003, 10:52 AM
84
They make a Torque Tab (T-H Marine) It helps to eliminate some of Your right hand steering torque.Screws on the bottom of Your hull.But if You had Tabs down , I don't think this is Gonna Help !! Did You check Yet & see if Your Cupped.I'd like to follow this one thru.NOT that I want this Problem (Or Expecting)My bet is Your engine is not PERFECTLY straight up & Down.The faster Ya go the More list/twist You'll get .
Scream'n Reels' [img]images/icons/confused.gif[/img]
www.frenzie.com
Old 06-04-2003, 11:48 AM
Well... I've seen a hook caused by many things. Most common is from sitting on a trailer that was not adjusted right. Too much of the boat hanging off the back unsupported. Thus caving-in the last 2 to 3 foot of the boat, making a reverse trim tab to say. This will make the stern lift or in your case lay over at speed. If the boat hasn't been this way long it may come out just by reblocking the boat on the trailer to hold the boat the right way or use a bunk trailer. You may have a soft spot in your hull and underpower the hull will buckle causing the list. I would put a straight edge on the hull and look for cups in the hull, they will be large in size and width. Once you find it then you can figure out what caused it and then how to fix it. I know the hook fin is for taking out feed back in the steering, but I've seen it work for list to a point. Does this happen with the motor trimed up or down..Do you trim your motor up and use the tabs?. I had a 25 grady that would roll at speed like you say. Though watching someone else run the boat for me and riding on another I notice that the motors where kick under when trimed down. I moved the pin up one hole and the boat never did it again. Your motor may be causing the problem try move the motor down one bolt hole and put the trim pin back one hole so the motor doesn't kick under as far and use the tabs to bring the bow down. you could be running to flat and the boat is chine walking and falling over to port because of the motor rotation.
Don Battin
Pipe Dreams Marine
"Design her right,
Build’er well
Bend the throttles,
And let’er eat…."
Carl Moesly
Old 06-04-2003, 11:55 AM
Eric,
That fin is located on the lower unit on the underside of the trim tab. It can be rotated to counteract prop torque.
Old 06-04-2003, 12:53 PM
Pipe Dreams...I'll check for the cupping. The boat is currently on, and has been for the last two years that its not in the water, on a bunk trailer. This may be a dumb question but should the cup appear on the port or starboard side. And if there is a large cup, how can it be corrected?
