Old 06-11-2003, 07:42 PM
duckoff duckoff is offline
Default Fuel sending Unit for 18CC
Has anyone replaced the fuel tank sending unit on a 18CC. If so which brand and
type did you use? I need to replace mine and the gauge and am looking for direction. Thanks, Paul
Old 06-11-2003, 09:03 PM
toadfish toadfish is offline
Default Re: Fuel sending Unit for 18CC
Paul, I replaced my entire tank and put in a new sending unit. I'm not sure the brand right off hand, but I think most of the units will be about the same. You just have to really make sure you get the measurements on the float cut the correct length and then may have to do some fine adjustments. After tinkering with mine for a while, I finally went with an in-line fuel flow meter (Navman, about $149)and will never mess with the another sending unit. Not sure how much $$$ you want to spend but it really does seem to be a great thing, especially if you will be burning a good bit of fuel...Toadfish
Old 06-20-2003, 05:33 PM
Thanks Toadfish, I am going to check the gauge before I replace the unit. I am
definitely going to get the Navman fuel meter. I just wanted a real fuel gauge as a
backup. Its a big ocean out there with no fuel!!!
