Old 08-26-2003, 01:01 AM
Rusty Bucket Rusty Bucket is offline
Default RePower?
First post on this site---be gentle please Recently a distant cousin sold me a '78, '20 MasterAngler that looks a little scruffy(well used)but seems to be very sound. It's on a cruddy but useable trailer and has some equipment and electronics. Power is an '85 140 Evinrude which he described as "wore out". I'm going to see if I can maybe revive it. It was running and shifting in summer '02. My neighbor has a 1989 225 Evinrude '20shaft off a bassboat. Looks real clean, faded paint but no corrosion. It's on a stand in his garage and he wants $1500 for it. Anything awful I should know about that era 225Ev? Are the mounting holes for the transom bracket maybe the same as the 140? If this works out I could be SeaCraftin' pretty cheap. I've wanted a SeaCraft for 'bout 30yrs. and finally bungled into a deal on one.
Thanks, Howard
I found this site this morning and have pissed away about 2.5hrs already!
If it ain't broke........gimmie a few minutes
Old 08-25-2003, 05:32 PM
Default Re: RePower?
Rusty,
Welcome to the site. I had the same engine on my 23 Sceptre and it finally kicked the bucket at the end of June. When we bought the boat 5 years ago the engine had only 250-300 hours on it and ran beautifully. A word of caution though - without a flotation bracket on the back of your 20 MA, that transom will sit very low to the point that you'll take water over with a couple guys back there. That 225 probably weighs 100# more than your 140. IMO, a 225 on that hull is overkill. Good luck. [img]images/icons/smile.gif[/img]
Old 08-26-2003, 11:02 AM
Scotts right, a 225 is probably too heavy for a 20 inch transom. I'm in the same boat as you as far as a motor goes. Its hard to find 20 in 4cyl motors. I had a 140 Johnson on another boat( very moody and expansive electrical parts that were exclusive to 120's and 140's) rebuilding an 85 might not be worth your trouble because the electrical will eat you alive. All the bolt holes are compatable.
Old 08-26-2003, 08:09 PM
Thanks ya'll, I was afraid of the weight. I'm big-n-fat, so that doesn't help either. I had an '86 110 Ev. on an old 18' Angler hull for a long time. Sweet running motor always. Is a good running 140 appreciably stronger than the 110? I hope. I had to use a lot of throttle(gas too) to keep the Angler going w/3 big adults aboard. I'm trying to thin out old car projects so I have time and room to mess with the boat. I see the tilt motor housing is badly rusted, but haven't gotten much farther. How much compound and buffing can the gel coat take on this boat? It's yellow and dull and dirty looking. Not scraped or scratched up much though. Thanks, Howard
Old 08-26-2003, 09:41 PM
barnacle barnacle is offline
The 1985 140 if im not mistaken is the looper version. Much, much stronger then the 110.
Old 08-27-2003, 01:10 AM
Thanks Joe, hopefully it's not too far gone to be revived. I think I might have found another similar year non running 140 I might try and nab for parts. I know this boat/motor combo was used a lot so I'm assuming the 140 must've been adequate power.
