Old 02-25-2002, 05:44 PM
Default PRICE ON A 225 YAMAHA 30"
I HAVE BEEN LOOKING INTO BUYING A NEW 225 YAHAMA
SALT WATER II
LOOK WHAT I JUST GOT BACK FROM BOATS.NET. "YAHAMA HAS DISCONTINUED PRODUCTION ON THE RIGHT HAND MOTOR FOR 2002?????????????????????????????? WHAT IS GOING ON??????????????????????????
The following information is provided in response to your inquiry to Boats.net.
Yamaha has discontinued production on the right hand motor for 2002. They are offering the left hand motor as the replacement.
LX225TXRA 25" $11,330.00
We have the right hand in a 2001 in stock, BRAND NEW, for $10,400.00.
Binnacle Control Box $225,cables $80, key switch $99, harness(16 ft) $52 for (26 ft) $82 for (31 ft) $152. . For two stroke motors that require an oil tank $240.
Single gauge kit (TACH DISPLAYS RPM'S,TRIM ,HOUR METER,TRIP,OIL AND TEMP INDICATORS (23 FT HARNESS)) $218.50
Dual gauge kit (TACH AND SPEEDOMETER KIT. TACH DISPLAYS RPM'S,TRIM ,HOUR METER,TRIP METER,OIL AND TEMP INDICATORS. SPEEDOMETER HAS BUILT IN FUEL GAUGE,VOLT METER,CLOCK,TRIP METER(26 FT HARNESS) $424.00
**** For a limited time we are running a "special" which will give you some additional benefits over and above our already low prices. You will be given a choice of receiving Free an ADDITIONAL TWO YEAR FACTORY WARRANTY, up to a $2,000.00 US SAVINGS BOND or ZERO DOWN, ZERO INTEREST, AND ZERO PAYMENTS UNTIL JANUARY 2003- NO Gimmicks. This promotion is while supplies last.
**NOTE: Sales Tax will not be charged on any motor shipped to an address outside of Florida or on any Boat & Motor Combination that is to be registered in any State other then Florida. We give a 10% discount on all rigging accessories purchased at the time of the motor purchase. All products come with full warranties. (Outboards: Two-Stroke- 2 year warranty - Four Stroke - 3 year warranty). Financing and all accessories are available from the dealer. You may contact the Dealer TOLL FREE 1877 41-BOATS (412-6287). *All Boat & Motor combinations are quoted as out the door prices except tax and title where applicable. There are no Dealer prep, or any other hidden charges.
Old 03-04-2002, 02:50 PM
Trayder Trayder is offline
Velvet Jones
Default Re: PRICE ON A 225 YAMAHA 30"
Ken-
Have you found anything further on this?
Old 03-04-2002, 04:11 PM
YA I TALKED TO THE BOAT.NET PEOPLE. THEY SAID THEY RAN OUT OF ENGINES DUE TO OMC GOING UNDER AND ARE HAVING A HARD TIME KEEPING UP WITH PRODUCTION AND ORDERS. THEY ASSURED ME NOTHING IS WRONG WITH THE ENGINES JUST THEIR ABILITY TO KEEP UP.
I DID GET A QUOTE ON A NEW 2001 EFI SALT WATER II 30” SHAFT FOR $8995, WITH A 4 YEAR WARRANTEE. I WILL PROBABLY GO WITH IT THIS WEEK.
FELLOW-SWHIP
Old 03-04-2002, 04:14 PM
Ken,
They are discontinuing because the are starting to get ready for next year Model. So they have to stop production on 2002 at some point. The motor is great, no problems, the demand was just high on this motor. The only change with the left hand would be the props.
The top portion on the engine is exactly the same as the right hand motor. The lower unit is counter rotating. The boat does not know what the direction the prop is turning so it runs the same.
----- Original Message -----
To: CFYAMAHA
Sent: Tuesday, February 26, 2002 8:38 AM
Subject: Re: QUOTE ON A OX66 225
THANKS MARY FOR THE INFO. I DO HAVE A QUESTION THOUGH WHY IS YAMAHA DISCONTINUING THE PRODUCTION ON THE 225 RIGHT HANDERS? IS SOMETHING GOING ON? I AM USE TO USING ONE ENGINE AND GOING WITH A LEFTY SEAMS LIKE I WOULD HAVE TO GET USE TO EVERYTHING RESPONDING THE OTHER WAY. PLUS BUYING NEW PROPS.
KEN MCGOVERN
Old 03-04-2002, 04:34 PM
Scott Scott is offline
Ken
How much did you pay for that???
HOw did you get that deal?? WOW!!! [img]images/icons/shocked.gif[/img]
Old 03-04-2002, 04:55 PM
HA SCOTT
I LOOKED IN BOAT TRADER MAGAZINE INTERNET SITE HERE IS FLORIDA THEN WENT TO ENGINES. WENT THROUGH THE ADDS ON DEALERS THAT SELLING NEW. MADE SOME CALLS AND E-MAIL GOT A QT FOR $8995.00 FOR THE 2001 225 30” SHAFT EFI THEY WILL SELL ME THE WIRE HARNESS OIL TANK DELUXE TYPE GAGES AND CONTROL BINNACLE FOR ABOUT $1000 THEN TAX. THIS WILL COME WITH A 4 YR WARRANTEE. I AM GOING TO DO SOME OF THE INSTALLATION AND HAVE THEM DO THE REST.
FELLOW-SHIP
Old 03-04-2002, 05:00 PM
Very Nice Thanks for the info!!!!
Scott
Ken did you replace the transom or did you put a bracket on the boat??
[ March 04, 2002, 04:01 PM: Message edited by: Scott ]
Old 03-05-2002, 11:03 AM
HA SCOTT
I DID THE TRANSOM WITH THE WEST SYSTEM AND 2 SHEETS OF Ύ” MARINE PLY WOOD. I ALSO ADDED A Ύ” WIDE SUPPORT TO THE INSIDE OF THE HULL FROM THE TRANSOM TO THE BOTTOM OF THE ENGINE WELL RESTING ON THE CENTER STRINGER AND GOING FORWARD ABOUT 1 ½’ WHERE THE OLD LIVE WELL USE TO BE FOR ADDED SUPPORT.
I RE DID THE DECK WITH ½” MARINE PLY AND WEST SYSTEM AND TOOK THE CAP OFF FLIPPED IT OVER AND RE DID IT AS WELL WITH ½ “ MARINE PLY. BUILD A NEW LIVE WELL WITH FIBERGLASS AND INSTALLED IT WHERE THE NEWER SEACRAFTS PUT THERE LIVE WELL MINE IS 32 GAL WITH A THROUGH HULL SCOOP AND PUMP. MOUNTED THE TRANSDUCER THROUGH HULL ON THE CENTER LINE ABOUT 2’ FROM THE TRANSOM.
I ALSO REBUILT THE GAS TANK DECK OF Ύ” PLY. FOR A 120 GAL GAS TANK FORWARD OF THE OLDER 100 GAL THAT WAS ORIGINALLY THERE. THE NEW TANK TAKES UP THE AREA UNDER THE CENTER CONSOLE SO NOW I DON’T HAVE A STEP DOWN AREA UNDER THE CENTER CONSOLE I WILL INSTALL THE OIL TANK AND BATTERIES AND A FRESH WATER TANK UNDER THE CENTER CONSOLE ON THE FLAT DECK ABOVE THE GAS TANK. I AM STILL FAIRING AND PAINTING HOPE TO BE DONE SOON.
FELLOW-SHIP
Old 03-05-2002, 07:51 PM
Ken
Thanks for the response. I would really like to see some more detailed pics of what you've done to the boat. I think we share similar hull,console and deck layouts. As I posted about the bracket I'm trying to figure out what to do with the transom .... If anything at all. Transom is pretty solid as is .... But I'd rather fix it now than later...Or atleast thats todays thought.
Thanks again
Scott
Old 03-06-2002, 10:11 PM
JeffS JeffS is offline
Fellowship....Is the outboard your talking about the OX66 model?.....
