Old 10-07-2003, 02:34 PM
meads910 meads910 is offline
Default Best Engine for a 20ft CC
can anyone tell me how much weight is too much to put on the back of a 20ft CC? im looking to get as much fuel economy as possible but not be too slugish getting on plane. thanks
Old 10-07-2003, 03:00 PM
NAHIM NAHIM is offline
Default Re: Best Engine for a 20ft CC
Meads,
A Mercury 200hp Saltwater gives you that good punch. I'm curious to see what everyone thinks is the perfect motor for the 20c.c. A 150hp is perfect too and weight is just about identical.Why not that extra power when facing rough blue water.
R.NAHIM
Old 10-07-2003, 03:19 PM
Mark Mark is offline
When I initially bought my 20'CC, it had a 130hp Yamaha Saltwater Series engine on it and it would FLY. The boat only weighs 1650 pounds, you DO NOT need to get to the Big Rock in 20 minutes! For use around Morehead, Beaufort Inlet, Harkers, and well up the East Side towards the Atlas Tanker, you would be just fine with something in the 130-150 range.
As to specific engines, there is likely only one person among the membership of this site that will argue with you against the Suzuki 4-stroke 115/140's.....and it's not me.
Keep an eye on the weight, they are tail-heavy boats...
[ October 07, 2003, 02:21 PM: Message edited by: Mark ]
Old 10-07-2003, 03:41 PM
TUGBOAT TUGBOAT is offline
I bought my 20'Ma w/ 200 Mariner Flew !I have a 150 Merc.(carb.) still Fly's (Closer to the water)!give or take around 43.Any where in this range if You have a Ma their a lil heavier.Had to find the right Prop to get Me outta the hole & run.Mirage II .
Scream'n Reels' [img]images/icons/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 10-07-2003, 09:25 PM
captalbie captalbie is offline
Don't know about the older models, but my 2001 Seacraft sports a 130 hp Honda which weighs in at 500 lbs+, making trim tabs a must to get the bow down for a smooth ride [img]images/icons/smile.gif[/img] .
Old 10-08-2003, 02:04 PM
Joe R Joe R is offline
Have a 20 cc. 1970 w/ t top I had 3 repowers in the past 18 years 115 yam. 120 loop charged evenr. and now on 150 carb evenr .boat has orig 20 in trans. for size and weight of 150 . I found it best. on 450 hrs now . I do lots of trolling out to 25 mi offshore ,plently of power .and price of new 150 carb not bad,, try to find a new leftover at end of season....Joe R. Susie II
Joe R
Old 10-14-2003, 08:21 PM
So i Guess 580 pounds for a motor would not be too much? Also i am going to raise the transom 5in does this factor in to the equation
thANKS
Old 10-14-2003, 08:50 PM
"Does raising the transom 5# factor into the equation?" - NO, raising the transom does not affect how high your floor is relative to sea level, which is the real issue.
580#'s on a SeaCraft 20' without a floatation bracket? - makes my feet cold just thinking about it.
Old 10-14-2003, 09:08 PM
ocuyler ocuyler is offline
Meads,
For an outboard, I like the a Suzuki 140 4S.
For an I/O, I like the Cummins Merc 1.7 (120 HP)Alpha. At just over $9,000, and 650 pounds, It may be a tad heavy, but you won't be re-powering anytime soon...
Otto
Old 11-04-2003, 02:23 PM
Robert Fowler Robert Fowler is offline
I am in the process of restoring a 1974 SF20. After much research, I chose a Merc 200 EFI. Weight is very much a factor on this boat due to the close proximation of the deck and the actual waterline. Also, I have had this boat powered by a 135 Evinrude, 175 Mariner, and a 200 Johnson. 200 HP is ideal for me. The weight of the new Merc 200 EFI is the same as the 150 and I like the extra kick of a 200.
