Old 05-30-2002, 12:15 PM
Briguy Briguy is offline
Default Drain Plugs
What type of drain plugs does everybody use? I currently use 2 of the rubber stopper with brass type in my transom and baitwell drain. They seep, get covered with barnacles and sea worms eat the rubber. In fact this weekend while swimming and scrubbing my waterline, one of the drainplugs had come halfway out. Talk about SCARY! [img]images/icons/shocked.gif[/img] [img]images/icons/shocked.gif[/img] [img]images/icons/shocked.gif[/img] I am considering installing the brass screw in type. I am also considering glassing over the drain for the baitwell as I don't use it. Any thoughts or suggestions would be greatly appreciated.
[img]images/icons/confused.gif[/img] [img]images/icons/confused.gif[/img] Thanks
Capt. Brian
Old 05-30-2002, 12:45 PM
Scott Scott is offline
Default Re: Drain Plugs
Hi Brian
You hit the nail on the head.....put in one of those Garboard cast bronze drain plugs. Those rubber T handle drain plugs are a little scary ... but they have been used for a long time.
I would fill that baitwell drain ( if not in use) and grind the hull drain smooth and install the new drain plug....if for nothing more than peace of mind.
Scott
