Old 03-02-2003, 02:48 PM
Exraider Exraider is offline
Default inboard to outboard
Has anybody ever attempted to convert a i/b to a o/b
Old 03-02-2003, 03:45 PM
tangofniro tangofniro is offline
Default Re: inboard to outboard
i am attempting this raider. though i do not have much done as of yet.
Old 03-02-2003, 05:33 PM
some of the guys on this forum said that becuse of the prop pocket that there would not be enough water for the outboard I don't understand this becuse thereis enough water for the i/b wheel
Old 03-02-2003, 08:58 PM
Rich Rich is offline
Exraider,
Do you have the IB now? What model are you refering to?
Cape Marine Supply
Old 03-03-2003, 11:27 AM
Exraider,
It's not that there isn't enough water, it's that the pocket would create turbulent water that the outboard wouldn't be able to deal with. You'd end up with a really bad cavitation problem since the o/b wouldn't be running in clean water.
Old 03-03-2003, 05:48 PM
Tom
Its a 23 cc & I still don't understand why theres enough water for the i/b prop & not the o/b prop
Old 03-03-2003, 07:11 PM
GetReel GetReel is offline
Ex: The IB is a great boat, have you considered keeping it and repower given the cost of OB's vs.IB's? You can get a new 350 with tranny for $ 8,500 =/- or so. I have a 23' CC IB and it is an unbelievable sea boat with the IB and I would never try to convert this boat, especially to a single OB. The 23 IB is a classic and somewhat rare boat and if it's a Potter built you will be making a mistake. If your after twins, better to find an old beat IO model in need of transom work for the conversion to brackett and twins.
Old 03-03-2003, 07:55 PM
Jeff,
It is a potter & thanks for your advice the only reason I was considering the change was the wet bilge of these boats that destroy these inboards & I guess I'm tired of scraping my knuckles every time I change the plugs. [img]images/icons/confused.gif[/img]
Old 03-03-2003, 08:25 PM
EP EP is offline
Even though I think it would be a shame to convert an i/b, I have to agree that the wet bilge does a number on the engine. I recently sold my 23 with an I/O for just that reason. Every year the starter would be seized up due to the wet salty environment where it was mounted on the 350. I tried to keep the dryest bilge. I had to have 2 starters. One to rebuild while the other was being ruined in the bilge. Other than that the boat was awesome. I just hated that power configuration. I was looking for an outboard 23 to rebuild but settled on a 20 that I am Completing now.
Old 03-04-2003, 03:04 AM
Serenity Serenity is offline
Hi there! As to the problem of a wet transom, I had the deck raised for several reasons, the main one being a "dry bilge". I don't know the condition of your deck but if it is a problem, you could remove and do the following:
1)build a larger engine area for ease of maintenance.
2)raise the floor to have a "true" flush deck.
3)have your recessed in deck fish box made deeper and insulated and drain out from the bottom at day's end (if you trailer)
4)build any deck hatch with a raised lip so water doesn't drain back in bilge, etc.
It really would be nice to have the i/b (wish I had one). The above may cost but with the savings from staying with "original setup" it may be the answer. Before I raised my old boat's deck, I also had problems with moisture, starters,... .
Sorry so long winded.
