Old 03-06-2003, 12:11 PM
Tom Bare Tom Bare is offline
Default fuel capacity on 18?
I think I read here somewhere that the fuel tank on the old 18's was in the neighborhood of 36 gallons.
ALthough I have not checked it in years I had always thought I had 48 gallons. I have bought a Navman fuel gauge and would like to know how many galloons I really have at full.
Was there an option for a larger tank on the 18's? It's a 79 model.
Thanks,
Tom Bare
Old 03-06-2003, 02:25 PM
Trayder Trayder is offline
Velvet Jones
Default Re: fuel capacity on 18?
In 1978 the 18 came with a 30 gal useable alum tank, I have not found any options for a larger tank, Considering all I found was useable gallons I do not know the true capacity of the tank. [img]images/icons/confused.gif[/img]
Old 03-06-2003, 02:49 PM
Mark Mark is offline
I had a 1977 18' and the "useable" gallons amounted to about 27! Needless to say, that was removed and a new 50 gallon tank was installed.
I'm not sure how far they expected those inefficient 70's engines to go on 27 gallons, but I would have run out of gas on a daily basis. When I bought the boat it had a 140 V4 Evinrude on it (1986 model) and I would routinely burn through 25-30 gallons a day chasing albies off Cape Lookout in North Carolina.
Old 03-07-2003, 01:19 AM
bmaj319 bmaj319 is offline
I couldn't find a label on my tank, so I calculated the cubic inches, and used a formula I found on the internet to determine gallons. The tank in my 18 worked out to just about 50 gallons.
Old 03-07-2003, 07:26 PM
BMAJ-
Do/did have your tank out of the boat? What are the dimensions?
Thanks everyone!
Tom.
Old 03-08-2003, 12:16 AM
Scott Scott is offline
Tom...If you can measure the tank plug the numbers into this for a real close estimate of gallons
Length(in) x Width(in) x Height(in) /231
Old 03-08-2003, 08:24 AM
Tom,
When I first got my boat I yanked the console and tank access cover off so I could inspect the tank itself. At that point it was quite easy to get the measurements. I also pulled the fuel gauge sensor, stuck a mirror and snake light in and looked around. Everything looked pretty good, so I didn't replace it. One note for guys going from 2 stroke to 4 stroke motors is to drain and rinse the fuel tank to get the oil out! Good luck,
Brian
Old 03-08-2003, 11:05 PM
toadfish toadfish is offline
Tom, my 18' holds 48 gallons....Toadfish
Old 03-10-2003, 09:24 AM
Toadfish-
Thanks!!!! I'm sure mine is 48 also, I was worried I couldn't verify it. The boat was in FL for years [I'm in NC] and I hadn't put fuel in her in quite a while.
Thanks to everyone-what a site!
Old 03-12-2003, 09:11 AM
SUMO SUMO is offline
By the good old measurement of draining thew tank and filling it up completelly I have almost 50gal on my 1983 18'. My cousing has a 70's 18' and he has 36gal with a 175hp!!!!! He is at the fuel pump very often.
Tight Lines
