Old 03-03-2003, 07:22 PM
EP EP is offline
Default New 150 Johnson Prop Size?
I just purchased a new 2002 150 Johnson for m 71 20 CC project. Any advice from those with similar engines and boats on prop size for me would be great. Also, what do people think about the steering system, would a cable be alright or is the hydraulic a good choice?
Old 03-03-2003, 08:40 PM
SEAFARI SEAFARI is offline
Default Re: New 150 Johnson Prop Size?
EP- THAT ENGINE WILL MOST LIKELY NEED
A 19" PITCH PROP. STILETTO IS A GOOD
STAINLESS PROP IF YOU NEED ONE. YOU
SHOULD KEEP THE RPMS ON THE HIGH SIDE OF
THE RECOMENDED RANGE. THE
SEASTAR STEERING IS MUCH NICER THAN CABLE
AND YOU CAN FIND GREAT DEALS ON USED
SYSTEMS.
CHRIS
Old 03-04-2003, 06:35 PM
Mark Mark is offline
...a second vote for Seastar hydraulic steering.
Old 03-05-2003, 12:23 PM
buzzcutt buzzcutt is offline
I had a 78 20' Master Angler with a '95 150 'rude and swung a 19" SST. It would run up to 5200 RPM in light load (one person, less than half fuel).
Fully loaded for the Bahamas it would run up to 4900 RPM when trimmed properly.
Go with Hydraulic steering if at all possible. I did and loved it.
BuzzCutt
Experience: The ability to recognize a mistake when you make it again.
If you can't fix it with a hammer, you have an electrical problem.
Old 03-06-2003, 08:20 PM
barnacle barnacle is offline
I like to prop boats with there normall load. If your fishing 4 people loads of ice and other items then be sure to have all that in the boat while trying different props. YOu want the RPMS to be at the top range. If you lug a outboard it will have a very short life. The dealer that sold you the engine should prop it out with you. If the dealer will not work with you then I would try a 19 first.
Old 03-07-2003, 12:22 AM
EP EP is offline
Thanks guys, looks like the 19 is close. Where would one find used hydraulic steering systems?
