Old 03-24-2003, 02:15 PM
Jason LaVey Jason LaVey is offline
Default My 20 lists to port?
While under power my boat begins to list to port, the more power, the greater the problem and my trim tabs do not allevaite it. Anyone else experience this....? Any ideas, other than I am doing something seriously wrong.
I support something, but I can't remember what???
Old 03-24-2003, 03:49 PM
Default Re: My 20 lists to port?
What do you have for power? If you have an I/O check your motor mounts.
Old 03-24-2003, 04:21 PM
WHICH WAY IS YOUR PROP TURNING? IS IT A RIGHT OR LEFT HANDER? IF IT IS A LEFT HANDER THAT COULD CAUSE YOU BOAT TO LIST TO THE PORT A LITTLE.
FELLOW-SHIP [img]images/icons/rolleyes.gif[/img]
Old 03-24-2003, 04:26 PM
catman115 catman115 is offline
check the zinc adjustment right above the prop.The one used to counteract the torque of the motor to keep you in a straight line. not sure if you were talking about this..??
Old 03-24-2003, 09:55 PM
Hooper Hooper is offline
My 23 lists to starboard at rest, and a bit forward too, a bit annoying as water tends to collect in the starboard corner near the fish hold... but underway, I have tabs and trim it out.
Sorry I can't offer any meaningful insight.
-Hoop
Old 03-26-2003, 01:23 AM
TUGBOAT TUGBOAT is offline
Check underneath her & make sure its not cupping at stearn(Hull)?All the other post before are right on the prob. also ?????? If the trim tabs aren't correcting sounds like engine torq.?
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 03-26-2003, 01:30 AM
Thanks for the quick responses. I will try the suggestions. Hope it resolves the problem
