Old 01-10-2004, 08:47 PM
omaier omaier is offline
Default Wet Transom
Need some guidance ... I have a 1976 Seacraft ... I have replaced all of the original plywood coring in the hatches. I had a sneeking suspicion that my transom was also wet and confirmed it this afternoon. Using a hole saw, I cut a couple of holes on the inside of the transom to reveal the plywood coring. The inner fiberglass skin had good adhesion to the plywood and the plywood was still sound but it was completely saturated. The boat is an inboard so the transom does not get loaded that heavily. I would prefer not rebuilding the transom ... any ideas to dry out the coring? Any other suggestions would be greatly appreciated.
Mike
Old 01-11-2004, 10:19 AM
mikeinct mikeinct is offline
Default Re: Wet Transom
Check out rot doctor...There is a way to drill, dry-out, apply a rot treatment & then pour epoxy into a solid salvagable transom..Worth looking into..lots of good rebuilding info..Good luck, mike in ct
Mike in Ct
