Old 11-13-2002, 05:51 PM
Default Transom core materials
Question;
Has anyone replaced a transom with any materials besides plywood? For example, has anyone used Seacast as the replacement transom core material?
I realize wood is good, but are Seacast type of materials better?
Your thoughts. Thanks in advance
- Nick
Old 11-14-2002, 09:32 AM
Briguy Briguy is offline
Default Re: Transom core materials
I was just at a yard last night and saw a transom done with seacast. The guy had an old 22-2 aquasport. He cut out about the top 6 inches of the transom and raised it another 5" for a 25" motor. He made a plywood mould and poured seacast in. When dried, he removed the wood. To his surprise, the seacast shrunk and cracked in the corners. OUCH! That is not where you want a crack. Anyhow he was going to fill in the corners and then glass over it. I am not impressed with seacast. I redid my transom on my 23' and filled it in like an inboard with a cap. I used 2 3/4 inch marine ply boards with glass in the middle and then 2 layers on the outside and inside up to the rubrail. For the cap, I used 5/8 inch corecell. With only one coat of light glass and resin on each side, I can jump on it. Corecell is strong.(it looks smooth on the outside and like a honeycomp on the inside) As for a transom, I think what my fiberglass guy uses now is a very high density foam that is light, easily sandable and will never rot or let water seep.
Capt. Brian
Old 11-14-2002, 10:35 AM
HA NICK
I LOOKED INTO THE SEACAST STUFF BEFORE I DID MINE WITH PLYWOOD. I DIDN’T KNOW IF IT WOULD REALLY WORK AS GOOD AS THE ADVERTISING SAYS AND I KNOW PLYWOOD DONE CORRECTLY WOULD LAST A VERY LONG TIME. ON THE NEW COMPOSITE MATERIAL TRANSOMS THAT ARE NOW BEING DONE I HAVE NOTICED THAT THEY WILL USUALLY USE A THICKER WALL OF FIBERGLASS ON BOTH SIDES OF THE COMPOSITE MATERIAL THEN WHAT YOU HAVE ON OLDER BOATS. IF I HAD TO DO IT ALL OVER AGAIN I STILL WOULD USE WOOD.
FELLOW-SHIP [img]images/icons/cool.gif[/img]
Old 11-15-2002, 10:44 AM
TUGBOAT TUGBOAT is offline
I just redid My transom with "Poly Mac" 24# Density foam.It took a lot of research ? If You were to get hit in the Head with a piece of this(2x4) size You would fall before it would Break!
Heavy,Hard & closed cell.Works really easy.I was worried about compression @ motor mount.Thickened the fiber a lil'.Water cannot creep.I hope I made the right decision,I'll let Ya know in 20 yrs Ha Ha.Maybe the diff. in weight will give Me another 10 KNOTS !!!!!!!'83 MA
Scream'n Reels
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 12-16-2002, 06:38 PM
Thanks again for the feedback on this.
While pondering what to do with my failing transom (last summer), I ran into a "old timer" fiberglass man. He would not listen to anything but replacing the transom back with marine ply. He said " How old is your boat?" I said "25 years old". He said "I will guarantee the new plywood transom for 25 years". I said " Great, when will it be done?" He laughed " One week after you remove the old one!". I said (of course, he did not hear) "Smart Ass!".
Here is what "I" did;
- Removed engine, hardware, etc off the transom
- Cut the (already) cracked transom cap off (i used a dremel ceramic bit)
- Cut(dremel) the inside fiberglass transom liner ~ 2 " from the sides and bottom. (Note: I had the access through original outside vents, rear seats and a newly planned Bomar hatch cutout in the motor splashwell/bildge.)
- Remove the rotten transom core through the top and/or the inside. ( I used the old New England chain saw for most of it! Careful!!)
With the old transom core and inside fiberglass liner removed,
Here is what "he" did;
- Make a template (cardboard) of the transom
- Using the transom template, mark and cut out two pieces on 3/4" marine ply
Now he needed to make the 2 transom pieces into 4 pieces in order to slide down and around the top deck rear corners of the transom cap. He just cut vertically ~8" off each piece on opposite sides to staggered the seams.
- Wet pieces and inside transom with resin, slide new transom pieces into place through the top
- From the inside tape and resin all seems
- Re-drilled holes for motor, hardware, splashwell and bilge drains
- Had a SS transom cap/plate made
- Re-mounted engine
Then "I" went back to fishing!
- Nick
