You guys didn't tell me that breathing the West System vapor would make give me a reaction. I woke up with my eyes all puffy. I didn't smell anything and didn't sense any risk. My brother says I should have all my brain cells back for a Spring launch.
I used alot of 2 part turning this mess: into this: In 50 years, this panel will still be solid! Otto
Otto And yes, I still believe in the four boat theory... |
Nice work--
Looks like you even managed to autograph it.... [img]images/icons/grin.gif[/img] |
Otto
First thing I would do is try to get a hold of the MSDS sheets for whatever you were using. What about fiberglass dust during the prep work and cutting the new fiberglass cloth??? That’s a major irritant .... Keep your hands out of your eyes while using any of this stuff (due to irritation due to contact) and If I were you next time I'm around this stuff I'd use at least a half face respirator with chemical filters (or whatever west system recommends) I've used both the Epoxy and Vinylester resin.....Never had problems with the epoxy ...... and never was around the vinylester without a respirator....Talk about killing brain cells !!! Remember everyone reacts different to these things ...... you may very well be "allergic" to what your working with. Oh .....nice deck [img]images/icons/wink.gif[/img] |
Hey Otto - That panel looks sweet, that is one looong panel, which is it,I didn't have any that big on my 23.
As to the puffiness, I think Scott hit it.It is probably the glass.Did you chip out the old core, and then recore all in the same time frame?Cutting out the old inner skin puts a lot of glass fiber in the air, and your eyes being moist an unprotected - that will do it, esp if they're sensitive.You could try goggles,if you can get them not to fog up on you. Another thought is that sometimes if you have a heater burning gas in your work area, I have noticed you can get some irritation when working with epoxy or even oil based paints. Anyway, nice work! |
Nice job Otto! [img]images/icons/grin.gif[/img] Thats a big hatch [img]images/icons/shocked.gif[/img] , I hope my small one comes out that great.
I support the I'm glad I can afford one boat theory! |
Otto,
Youshould try MAS expoxies! They were developed by someone who had reactions to West System, plus its stronger and thinner. They also make a thicker resin comparable to West sytem called Flag. Looks good, is that the hatch cover for the fuel tank in a 20? I did mine in COOSA reinfrced Foam, with a biaxla cloth over top, then gel coated, pleanty strong, will never ever rot. Cheers, JW |
