Old 03-10-2003, 02:16 PM
EP EP is offline
Default Foam between stringers
What kind of foam should I get for between the stringers and where should I be able to get it?
Thanks
Old 03-10-2003, 07:29 PM
EBEACH EBEACH is offline
Default Re: Foam between stringers
use a two part foam mix, 2lb density. Your fiberglass supplier should carry it. Or check with an online supplier.
http://www.raka.com/
http://legnosboat.com/productindex.html
http://www.uscomposites.com/products.html
http://www.fiberglasssupply.com/default.asp
Old 04-03-2003, 03:38 PM
EP EP is offline
the two gallons of the foam goes 9.2 cubic feet, has anyone else refoamed their 20 cc and how much did they use? not too sure how much I should get.
