Old 03-19-2003, 08:59 PM
Jon G Jon G is offline
Default Need a source for thru hulls
Guys I need a source for a couple of thru hulls for my two bilge pumps. I need 1 1/8 by 90 degree fittings. I want to put them up in front of the SeaCraft lettering to get them as high as posssible but I have limited room between the liner and the outside hull. I found a nice fitting made by Orca but I measured tonight and its slightly to long to fit. These fittings were a nylon/glass with the stainless on the outside. I'd rather to with metal versus plastic but I'll take anything to get the boat in the water. Any ideas?
Old 03-20-2003, 12:51 AM
Scott Scott is offline
Default Re: Need a source for thru hulls
Jon ...this what you want ????
www.gemlux.com
Old 03-20-2003, 01:07 AM
more info ....
http://www.gemmarine.com/pdf/75004.pdf
Its #75004.... type that in on the website and you'll find it ..... the website is a bit difficult to find stuff (but I have a hard copy of the catalog [img]images/icons/grin.gif[/img] ) and it makes finding stuff much easier esp. hinges .... they have about 1,000,000,000 different kinds That thru hull is around $30 and its solid stainless (have many different sizes.... [img]images/icons/smile.gif[/img]
Old 03-20-2003, 09:35 AM
jw jw is offline
Perko makes the what you are looking for.
JW
perko fittings
So does rule the pump people.
www.bansheecharters.com
Wishn' I was Fishn"!!!!
Old 03-20-2003, 06:37 PM
Scott thats the one. The one I found is just too long it would hit the liner. I'll check out there other stuff too. I've been searching for "thru hulls" on the net and have not come up with much. JW I'll give the perko a look to but I think I found what I'm looking for. Thanks for the info guys. [img]images/icons/grin.gif[/img]
