Old 05-06-2003, 11:13 AM
Brian Rice Brian Rice is offline
Default Decks
I was just wondering what the going rate was to replace the whole deck in the 23' CC? If anyone has had this done recently I would like to know what the cost was.
Thanks.
Bri
Old 05-06-2003, 12:53 PM
CMBarnes CMBarnes is offline
Default Re: Decks
I am getting the deck replaced in mine up to the forward casting deck. I am hoping to get a quote from the guy in the next few days and will let you know what he says. I know the new deck will be made out of this wood that has a life time warranty against rot. It is supposed to be great stuff.
CMB
Old 05-06-2003, 02:11 PM
Default Re: Decks
DID MINE FOR ABOUT FOUR 6 PACKS OF BUD AND ABOUT 10 TO 12 DAYS OF HARD WORK PLUS MATERIALS.
FELLOW-SHIP [img]images/icons/grin.gif[/img]
Old 06-10-2003, 03:42 PM
Default Re: Decks
I just wanted to bump this back up to the top to see if anyone has any numbers for me.
Old 06-10-2003, 04:07 PM
Default Re: Decks
Had my deck redone this spring. There were soft areas on both sides of the console. Used a different method from what I've seen posted. I used a 2 1/2" hole saw to cut out sections (150 holes) of the deck skin, being careful to only cut thru the top skin. Made a tool out of a screw driver to scoop out the rotted balsa core( some of it was like mud). Drilled the holes close enough so that I could get out the balsa between the holes. Used 3/8" foam blocks for spacers between the top and bottom deck skins. Filled in the void between skins with 510 Multibond putty,putting the 2 1/2" deck plugs back in place. Covered the deck with one layer of biaxial cloth. Rolled on a coat of gel coat with non skid. Came out sweet, very solid-like walking on the sidewalk.I did the grunt work,the finish work was done by a pro.Total cost about $100 for material and $300 labor.
Old 07-09-2003, 07:33 PM
capexcape capexcape is offline
Default Re: Decks
I have the same problem and am hoping to do it soon.If you could could you send any more info or name of person that did job I would appreciate it.
I have a 20 cc seacraft 1972 and really want to keep it in good shape.
Thank you
Dave Amaral
Capexcape@yahoo.com
Old 07-17-2003, 09:26 PM
Default Re: Decks
Scott Thanks for the E mail reply I plan on redoing the deck this winter and this will get me started in the right direction
Dave
