Old 08-29-2003, 09:15 AM
abl1111 abl1111 is offline
Default 23' Tsunami- lift eye support necessary ???
My '75 Tsunami does not have the lift eye installed in the bow deck ( although there is a hole for it )- therefore it does not have the threaded rod / support that normally would connect this bow lifting eye to the trailer eye ( located on the hull right above the water line )for support. This threaded rod would normally be located in the anchor locker.
Is this threaded rod/support important for support if I never plan on lifting the boat via the bow eye ?
I have all the parts, I just do not know if it is needed for bow support.
Old 08-29-2003, 02:40 PM
Default Re: 23' Tsunami- lift eye support necessary ???
If you're not using it to lift the boat then don't bother with it. It'll just be in the way.
