Old 01-05-2004, 11:11 PM
wildlifeone wildlifeone is offline
Default 1972 seacraft 23 cc for sale
I have a 23 cc i/o conversion with an Armstrong Wide Body flotation tank bracket(2002)with a2000 Evinrude 225 hp ficht Appx 300 hrs motor is under warranty till 2007.This boat has an aluminum 1999 loadmaster trailer.1999 aluminum t-top,2002aluminum leaning postw/back rest, new fuel tanks,rear floor has been modified so you cant tell it was an i/o(flat across no lip).the inside of the boat has just been paintedw/the console. the cap has been removed and recored.it has the large console.new gauge panel and custom switch plate,has the bow rail like the contender does from e-tec,Thus boat has tons of storage.nav man depth w/fuel calculator,cdplayer,vhf.hydraulic steering(warranty)No soft spots in floor! The vents in the hull have been glassed in! I have not painted the outside of the hull yetbut will if you want or you can it is still seacraft white .thats all this boat needs to have a total refit!!It also has accon flush mounted bow light.w pop up cleat. .I am seling it because Iam buying a house.
26,100 obro pls email dixieplantation@bellsouth.net
