Old 03-29-2003, 06:35 AM
CRO CRO is offline
Default Opening photos
Dose anybody know why that when I try to view Ken Mcgoverns 23 pics AOL quits? Is this happening to anyone else? Thanks.
Old 03-29-2003, 10:15 AM
Mark Mark is offline
Default Re: Opening photos
sounds like a question for aol
Old 03-29-2003, 06:43 PM
John R John R is offline
Is that Ken McGoverns pics on this site? Or on the boatzone?
Surf and Boat fishing for
Striped Bass
Old 03-30-2003, 07:12 AM
CRO CRO is offline
On this site. Everytime I click to open his pics the first one comes up then a message from AOL saying they have encountered a problem and have to close and I go offline. It just happens with his pictures. Very strange. Thanks.
Old 03-31-2003, 10:55 AM
JohnS JohnS is offline
Chris,
Your computer is most likely running low on memory and AOL is a memory hog. Try to increase your virtual memory and then see if it still happens. Usually you would have "Let windows manage" checked off. Uncheck and specify something on the large side and see if that works. Also, if depending on your operating system, you should slow the read ahead down, this fixes the problems most of the time too. If you need specifics on how to do all of this, just email me and I will go point, by point, click by click for you......
John
John
Old 05-08-2003, 10:19 AM
cc cc is offline
enjoyed the photos. I have a 1965 seacraft 19, bowrider, i/o, mercruiser 6 cyl,150 hp, 1C outdrive, serial #315, model 3+3, purchased new 6/29/1965 by my father, and purchased by me in 1974 when he bought a larger boat. I spent many hours as a teenager operating this boat as I had just gotten my drivers license that year. I put a new head on the engine and a freshwater kit on it in 1976 as I was then living in tidewater, va. and boating in saltwater. The boat still looks relatively new, and runs like a top. I have all orginal receipts, ads, warranty cards, seacraft placemats, orginal top, side, and aft curtain, and use the boat regularly. Have thousands of hours on it, and still have not found anything better in its size. Hull is light green, topside a darker green. I did drill holes in the floor in 1983/4 and put closed cell foam in between the hull and innerliner. This really made the hull stiff, and only added about 100 pounds to the weight. I am on my third fuel tank. Orginal was galvanized, and have aluminum now, 28 gallon.
