Old 01-25-2004, 02:05 PM
el pescador el pescador is offline
Default smallest truck to tow 23 ft up boat ramp
with your average boat ramp whats smallest truck size would be to pull a 23 ft. seacraft up a ramp ....i have a extended cab chev.1500 with a 342 rearend with locking differental and the small v8 engine..manual say 6200lbs ....boat is a 1983 center console ,would the 1983 models weight more than the potter built for i think this boat dry wt. 3400 lbs any i correct
Old 01-25-2004, 02:15 PM
Default Re: smallest truck to tow 23 ft up boat ramp
View this Thread my Friend [img]/images/graemlins/wink.gif[/img]
Re: Tow Vehicle for a Seacraft 23CC
#2472 - 10/28/03 06:44 PM
Old 01-25-2004, 05:17 PM
ocuyler ocuyler is offline
Your 1500 will easily pull a 23CC up any ramp in low gear. The 305 with the 3.42 gears is a very light set up for any distance beyond the ramp. As previously discussed here, a 1500 with 5.3 or 5.7, 3.73 gears and a trailer package is pretty much the minimum for highway hauling.
Otto
Old 01-25-2004, 06:27 PM
The smallest truck size? Well, before I got my F150, I would tow our 23 Sceptre with a Chevy Blazer (the small one) to and from the ramp - 7 miles one way, back roads. But this was only to splash it in the spring and haul out in the fall. I'm certainly not recommending this, but at the time it did the trick, and I was within the tow capacity of the vehicle (5,600#s), albeit marginally. The Silverado you have is more than capable.
Old 01-28-2004, 08:45 AM
This should do the trick. [img]/images/graemlins/shocked.gif[/img]
www.f650pickups.com
