Old 03-01-2004, 09:05 AM
JW-Tex JW-Tex is offline
Default Hull to Liner/Cap joint
I need to resecure the hull to cap joint, my plan is to use sheet metal screws, and 5200, then from the inside cut access holes (deck plate hatches) and epoxy the back of the joint with two layers of roven. Once cured I plan on replacing the sheet metal screws with bolts and washers where I can reach them. I would appreciate other ideas or comments on this approach.
Old 03-01-2004, 11:18 AM
TUGBOAT TUGBOAT is offline
Default Re: Hull to Liner/Cap joint
JW Tex
I re-glassed a strip around the inner side of the gunnel (hull) ,Then when i put the topcap back on I had a new Bite.I used # 10 Flat head SS screws counter sunk12-14"sPre-drill pilot hole,Then I thru bolted # 10's between them Flat washers & Nylon lock nuts .This also gave Me a place to tie wrap the wiring from the Bow.I would not 5200 inside the seam.If you ever have to take it apart ,Jerry Clower has some M.ChainSaws in a Muesem. I put a bead at every screw then a bead all around the out side(under)(fast cure,less drip).I then put the rub rail on ,then another bead of silicone to smooth out the rail to hub.Sho is quieter than before,dryer too.
Scream'n Reels' [img]/images/graemlins/cool.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
