Old 03-20-2004, 04:30 PM
meads910 meads910 is offline
Default Need some electrical advise
Well I just got the boat back from the fiberglass guy with a raied transom, new glass on the bottom where it had been ran up on the beach for years, and the rod holder holes fixed
now it is on to electrical; just wondering where I can get a new harness, batteries, and switches
another question; are the courtesy lights and navigation lights on the same harness as the engine harness or are they seperate.
thanks
meads910
Old 03-22-2004, 04:01 PM
Briguy Briguy is offline
Default Re: Need some electrical advise
As far as batteries, go to Sam's club. They are about 20-50% less price than anywhere else.
Capt. Brian
Old 03-22-2004, 08:42 PM
jw jw is offline
Meads,
Not sure of your rig! However the engine harness is going to be separate from the boats electical system, IE lights, bilge pumps etc. I think if you searc the data base here there was a cataloq of electical supplies that were not teribly expense. Do not skimp in using automotive wire verus marine grade wire.
Hope this helps and good luck,
JW
www.bansheecharters.com
Wishn' I was Fishn"!!!!
Old 03-23-2004, 07:55 PM
JW
thanks this helps me out alot. as I now know which harness to pull out of there. Any suggestions or ideas for running new wires to replace the old ones that go to the lights, and bilge pump, etc
thanks
nick
Old 03-24-2004, 08:01 AM
One suggestion I can make is don't pull out the old wiring until you're ready to run the new. You can tie or tape the new wires to the old and fish them through, this way you don't have to re-run the new stuff blindly.
Old 03-28-2004, 12:32 PM
jw jw is offline
Nick,
If you go to the ABYC website (google it) it will give you the proper colorcodes for the wiring for everything. I generally used 12 gauge ancor wire, have a box full of different colors , and heat shrink ends, i also use dielectric grease on all connections. Corrosion is noones friend.
JW
