Old 07-04-2004, 09:54 AM
doug7488 doug7488 is offline
Default 1972 18' cuddycabin seacraft
1972 cuddy i/o. engine & drive removed. Was set up for omc drive. includes trailer. solid boat, needs resto-$500.-
Located on Long Island,NY (631)842-5333 [img]/images/graemlins/grin.gif[/img]
Old 07-04-2004, 09:56 PM
Mark Mark is offline
Default Re: 1972 18' cuddycabin seacraft
an 18' cuddy sounds intriguing, any photos?
Old 07-05-2004, 11:12 AM
The boat is very similar to the 20'. The floor, deck and transom are all very solid. It is shrinkwrapped right now. If you are seriously interested, I will uncover it & send pic's. Where are you located?
Old 07-05-2004, 09:43 PM
I was merely intrigued due to not knowing that any 18's were set up as inboard cuddy cabin boats. I have had both the 18' and 20' CC and was unaware that the setup you describe existed. I learn something new everyday.
Old 07-11-2004, 09:42 PM
I am interested. Do you have a serial # and an exterior photo?
It's a long way from FL to have a look.
Old 07-16-2004, 12:33 PM
I'm looking for the regi right now, anyway.. found the bill 0f sale says Vin # DK 699067 I assume those #'s to be correct. I will contiue to look for regi. I looked on the right rear transom where most vin's are but didn't see a #. Without tearing the shrinkwrap off, is there another place they would have put it? The boat looks just like the one on your sign in. Will post pic's soon.-dg
Old 07-16-2004, 12:37 PM
OK found regi- My bad, boat is a 1970 & is 20'! I should look at these things before I swear by them!
Vin # DK 699067
Old 07-16-2004, 12:40 PM
Doug,
After '72, the CG required mfg's to place the HIN on the transom. With your boat being a '72, you're in a gray area. My '72 Seabird has the mfg's serial # on a plate inside a storage locker. Take a look around, I would think there is a plate somewhere that lists weight limit, HP rating, etc. By the looks of the HIN you give, it might have been assigned by the state in which it was titled.
Old 07-16-2004, 12:44 PM
Thanks for the reply, Scott, as usual I gave out false info ( although not intentionally!) - found the regi, it's a 1970 & 20' !! - Who knew ?
Old 07-16-2004, 12:46 PM
That explains everything then. When you originally posted an 18' cuddy, I wondered if you really meant a 20' Seafari.
