Old 07-16-2004, 08:25 AM
Abe's Rocket Abe's Rocket is offline
Default Hot Wires????
All...
When cranking over my 76' 200hp evinrude, the positive battery cable, from the motor to battery, will start to smoke and get extremely hot. I have never seen this before and can't imagine its a good thing.
Any suggestions / ideas are appreciated.
Abe's Rocket.
1973 Seacraft 20ft cc.
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 07-16-2004, 09:47 AM
optiguy optiguy is offline
Default Re: Hot Wires????
The first thing you should do is clean all the connections on the Batt leads. Especially the ground to the motor and Batt and the Hot to the starter. Usually hot wires are from high resistance due to weak connections.
Bill
Old 07-16-2004, 10:09 AM
or a weak battery???
1986 Seacraft 23CC
etec 250
Portland, Maine
Old 07-16-2004, 12:35 PM
No. You wouldn't have a resistance problem if your battery was weak. Check your main connections, clean the terminals, and clean/check the connections to your starter. That starter needs a lot of juice to crank.
Old 07-16-2004, 01:00 PM
It may not be just your connection at the motor. If you have a battery switch in the system the bad connections could be there as well. If It looks green on the ends its best to cut back the cable a bit and put new terminals on.And, if the switch is old or origional its internal connections can deteriorate as well. You may need to replace it too. Frequent problem on older wiring.
Old 07-17-2004, 07:50 AM
FlytheCoop FlytheCoop is offline
Sometimes the whole battery cable has deteriorated and needs to be replaced...I had the same thing happen. I replaced the battery leads and the boat started much quicker and the wires never got hot again. The wiring was probably 15 years old at the time.
Old 07-17-2004, 01:31 PM
RS RS is offline
Fly... is probably right. The heat is usually generated where the high resistance is located.
Best regards,
Roger
1979, 20' Master Angler
Old 07-21-2004, 12:48 PM
Thanks for all your feedback, while looking deeper into the issue i noticed that the cables were completely shot. A buddy of mine gave me a spare set and I am back in business...ahhh the joys.
1986 Seacraft 23CC
etec 250
Portland, Maine
