Old 10-27-2004, 08:47 PM
gbf03 gbf03 is offline
Default fuel range in a 20
This is a pretty broad question but those of you with 20s what is your fuel range with 150 or what is your guess on my boat. It is 1978 20 sf with a 2001 merc efi 150. The boat has a 50 gallon gas tank. The reason I ask this question is becuase I will be finishing my boat in the next week and half,(hopefully) and I wont have time to really test my boat out before I have a fishing tournament that I am competiting in. If all goes as plans I will be able to splash the boat in the fsu lake and test it out but I wont be able to test the range.
Thanks,
George
20 SEACRAFT SF / 29 SEA VEE
F.S.U. / REEL SWEET FISHING TEAMS
Old 10-27-2004, 11:02 PM
Ryan Ryan is offline
Default Re: fuel range in a 20
you should be able to cruise at 2miles per gallon so 100 miles is probably a safe guess [img]/images/graemlins/confused.gif[/img] Are you fishing offshore? I would try and get out and do a test run asap good luck
Old 10-28-2004, 02:41 AM
George,
This probably doesn't help a whole lot, but I think you'll be better 3+ mpg at cruising speed. If you're concerned then bring an extra jug along or buy a flow meter.
My old wellcraft v20 with a 200hp yamaha which was much much heavier than a 20ft seacraft would average 2.8 - 3.0 mpg @ 30mph : navman.
Old 10-28-2004, 09:58 AM
George,
Remember that you can't use the total tank capacity in your equation. You probably have 45 usable gallons.
Old 10-28-2004, 10:14 AM
Mark Mark is offline
George,
I'm no fan of guessing, and none of us have your exact setup (even if someone has a 20' with that engine, the two will suck fuel differently). So, for just a small amount of peace-of-mind, if you are concerned about it you might think about the five gallon jug like a previous post suggested.
I have a heavier setup than you with a t-top/75 gallon tank/all wood redo/ 4-stroke engine/ etc. and at 4,000rpm I get pretty decent mileage according to the Floscan unit, but without testing it, anything about your situation is merely a guess.
Old 10-28-2004, 11:21 AM
gw204 gw204 is offline
I can get over 3.5 mpg cruising an '02 carbed Merc 150 at 4000 on a 20' Grady White CC. My boat is a bit heavier than your 20' SeaCraft so on calm water, I would expect every bit of 3.75 mpg from your setup.
These Merc. are very fuel efficient. [img]/images/graemlins/smile.gif[/img]
Brian
1981 Mako 17
Old 10-28-2004, 12:19 PM
Yea I was trying to get a general idea, since I have never ran this set up before. I am gonna figure less than 3 miles per gallon becuase I wont be running the boat at cruising speed at all times and I dont know the motors' performance. Thanks for all the info.
-George
Old 10-28-2004, 12:52 PM
Another comparison for you george....
Two summers ago, I ran approx. 30 miles at about 3000 RPM (twas a rough morning), trolled for about 7 hours at 6 kts, then ran about 25 miles back at 4000 as it had calmed down nicely. I covered about 112 miles on 43 gallons. My Navman told me I was drinking about 2 gal/hr at the 6 kts.
Brian
1981 Mako 17
Old 10-29-2004, 07:28 PM
FXRSCOTTY FXRSCOTTY is offline
20 footer scepter with 135 merc carbed motor will get an easy 3 mpg at 3600 rpms. At least mine does. I have a dole fin no tabs. Hope this helps. Scotty.
FXRSCOTTY
Old 11-02-2004, 03:09 PM
FlyDoc FlyDoc is offline
George,
I have 2003 20' Master angler with 150 Yamaha HPDI a 70 gallon tank and coffin box console. Last wednesday in a solid 2 foot chop on Long Island Sound I ran 2 hours at 28 mph. When I refilled the tank I had burned about 12 gallons of fuel.
Chris
