Old 01-04-2005, 05:08 PM
ztagator ztagator is offline
Default trim broken
Went to put muffs on engine today and the engine wont go up or down. The trim motor is humming, but the engine is not moving. Any Help?
Old 01-04-2005, 08:03 PM
Trayder Trayder is offline
Velvet Jones
Default Re: trim broken
Check the trim fluid
Old 01-06-2005, 02:03 PM
NOAHSARK NOAHSARK is offline
I JUST FINSHED REPLACING MY TRIM BECAUSE IT WAS STICKING ON ME. I WOULD FIRST CHECK THE FLUID LIKE TRAYDER SUGGESTED, IF THAT DOSENT WORK YOU WILL THEN NEED TO TRIM UP YOUR MOTOR MANNUALY AND START TROUBLE SHOOTING. IF IT'S GOT FLUID MAKE SURE TO FOLLOW UP ON YOUR POST AS I AM SURE MOST EVERYBODY HAS EXPERIENCED THIS PROBLEM BEFORE. [img]/images/graemlins/wink.gif[/img] GOOD LUCK!!!
GOD BLESS, TIGHT LINES!!!
Old 01-06-2005, 09:12 PM
Mi Time II Mi Time II is offline
Mine was doing the same thing put some fluid in and works fine. Still going to take it in and have checked tho.
Old 01-08-2005, 11:49 AM
Like Trayder said above it's definitely a low fluid issue.
You'll need to figure out where the fluid has leaked out. After you add fluid, clean off the hydraulic rams and watch for leaks around the seals.
What engine do you have?
