Old 03-14-2005, 06:12 PM
TUGBOAT TUGBOAT is offline
Default oil leak ?
I have an oil/fluid leak under the cavitation plate. 1995 mercury 150. there are 2 holes just under the cavitation plate.It looks like water intakes.theres oil seaping out of the forward one.The motor stays tilted up & has been like this.Never noticed it before.Any ideads ? [img]/images/graemlins/confused.gif[/img]
www.frenzie.com
"Classic SeaCraft" Lures
My wife and I had words,
Old 03-15-2005, 01:54 PM
Default Re: oil leak ?
Yup. You need to replace your shift-shaft seal or upper driveshaft seal, or both. (I'm betting on the shift-shaft seal) [img]/images/graemlins/frown.gif[/img]
Old 03-16-2005, 05:00 PM
Huh? UPPER [img]/images/graemlins/shocked.gif[/img] I hope it's the Bottom one! I'll check it out soon.I'm fix'n to replace the lower fluid & water pump.Just could'nt see where it would come from.
Thanks !! [img]/images/graemlins/cool.gif[/img]
www.frenzie.com
Old 03-17-2005, 10:44 AM
littleminnow littleminnow is offline
I had a classic 50 merc,I also had it tilted and expected the worst when I saw oil on the ground.BUT thank God my auto oiler was bad,so the oil just flowed free out the bottom.something to check,
